Where can I find some ride height specs? Curious if my '79 supercab 4x4 is taller than regular cab due to the front leaf springs. Also wondering how it compares to the highboy. All I can find is the highboy is about 2 inches taller than a lowboy. Doesn't help much in my case as I'm wondering if my supercab is taller than reg cab so might be closer to highboy height. Know what i mean? Thanks.
My supercabs are are not anyway near as high as a highboy. same as any other 4x4 ford
John
From what I've read on here the difference in only about 2" so I don't know how easy you could really tell the difference; if they both were truly stock height.
check this out it has every thing you ever wanted to know about a highboy... but were afraid to ask
Yes, I read that and it's a great write-up but has no mention of '73-'79 ride heights. Unless I missed it. Gonna measure mine tomorrow and see how it compares to the '67-'72.
Closer to 3-4 inches difference nowadays with the negative arched springs sagging so badly over time, compared to the earlier trucks springs, which don't wear anywhere close to flat.
