78-79 Bronco factory lift
I have owned close to a dozen 78/79 Broncos in my time and have noticed that some have front coil spring heights of 13" installed while others have 15" springs installed. My question is, does anyone know the name that Ford gave to these trucks with the taller factory ride height? I've heard it called snow plow package but none of the 5 trucks I've owned with the taller springs have had any sort of ID on them to specify the package name for the taller height.
No such thing as a "factory lift". Heavier or longer springs would have been employed for some reason OTHER than increased ride height. Option packages aren't/weren't always indicated outwardly. The tow package, heavy duty cooling, etc were not indicated with badging or even referenced other than to be listed on a build-sheet or order form. So its quite possible they were part of a factory option package but not one that was outwardly designated with insignia.
The bronco didnt come with a factory lift but there was three different model CODES.
U 150, U 151, and U 152. they all deal with G.V.W. the first is 4400 lbs second is 4600 lbs and the third code is for the HD package at 4900 lbs I'm not sure if this is the right answer but this is all I could come up with for you.
Just a side note-I helped my friend put a 6.9 IDI in his 79 bronco a few years back and the stock 13 inch tall coil springs sagged too much with the extra almost 300lbs. of the diesel so we found a 78 Bronco with coil springs with a 15 inch installed height. Not only were the coils taller than his old ones, they hardly sagged at all with the extra weight. Point is that not only are the 15 inchers taller, they have a higher weight rating.
I'm unaware of a VIN designation or a door jamb tag to denote the difference in spring height but that really doesn't mean much except that its one more thing I don't know... yet. I don't have a 78-79 and never have (not that I'd turn one away if it wandered into the driveway). I'd say you are on to something that could use a bit of research. I don't know how many 78-79 owners would know the difference unless they had your experience with multiple units.
I wonder if it has anything to do with the quad shock or trailer special package? Mine is a trailer special with free wheeling stripes and clears 33"s no problem. It has the quad shocks. (also the radiator is for a 460 even though it has the 351m in it. It was built that way because it was stamped 11/78 when I changed it.) I had a friend that had one w/o quad shocks, non trailer special, but otherwise was almost identical to mine. It had the same stripes and paint although it would only clear 32" tires. Both were '79 Ranger XLT's. Mine has a 6400 lb gvwr. btw
The quad shocks in later years were part of the tow/trailer package but not exclusive to it. You could get them as an ordered item. However, I'm not aware that the springs were any different with the addition of the auxiliary (forward) front shocks. I'd be interested to know what the unloaded length of the springs you guys are dealing with is, if they are the same diameter (coil and steel) as the rest and which, if any of the F-series trucks got the same set. I have no information to help unfortunately, but like the idea that there are potentially OEM springs out there that add ride height.
