Leaf spring spacers
Old Dec 27, 2010 | 05:28 PM
JRS2's Avatar
JRS2
Leaf spring spacers
Not sure if any of you have done this, but those spacers between the leafs kind of deteriorate over time. Dealer likely won't have them, perhaps a spring shop. Wonder if any suggestions on things around the garage - maybe light sheet steel or sheet aluminum ? Plastic they use out near the ends but I am thinking in the center - where the bolt holds it together - it absolutely doesn't seem like plastic - originally. Have you done it ? What works for you ??
Old Dec 27, 2010 | 05:53 PM
thechief66's Avatar
thechief66
I bought some from a local spring shop for cheap, like a couple bucks each.
Old Dec 27, 2010 | 06:06 PM
Diesel_Brad's Avatar
Diesel_Brad
Just bolt the spring pack back together. you dont need those thin pieces of plastic
Old Dec 31, 2010 | 09:50 AM
JRS2's Avatar
JRS2
Thanks guys, I ended up making my own from sheet metal before bolting together. A little axle grease added to keep 'em from rusting right away ...
Old Dec 31, 2010 | 11:18 PM
xxshine's Avatar
xxshine
When the spring shop did the springs on my rig, they told me the same thing. Don' use the plastic spacer things.
Old Dec 31, 2010 | 11:33 PM
StumpPullerF1's Avatar
StumpPullerF1
I had some deaver springs that had those and they helped the springs slide on each other. Probably dont really need them but they still build all their springs with them... Mine squeaked a lot when they got dirt in them.
Old Dec 31, 2010 | 11:42 PM
xxshine's Avatar
xxshine
The spring shop said that the springs are not supposed to move, if the ' U ' bolts are torqued correctly. If the springs are sliding, might try going with a larger ' U ' bolt size. I use 5/8, and the shop says that those ' U ' bolts are only good for one time use. Apparently, they don't torque down correctly the second time around. With the weight i haul around, i'm goin w / what they tell me.
Old Dec 31, 2010 | 11:47 PM
StumpPullerF1
I may not be talking about the same thing... I meant the pads that are between each leaf in the leaf spring set. The "leafs" will slide on each other as the suspension cycles.
DarrellinCeres
Oct 6, 2016 03:19 PM
dtgl90vt
Jan 30, 2016 05:45 PM
bigboisteiny
Aug 9, 2014 09:35 PM
truckmonger1
Oct 25, 2009 07:30 PM
98SurplusExpy
Dec 7, 2007 09:40 PM
