Modular V10 (6.8l)
Engine dies while driving
Old Dec 27, 2010 | 03:20 AM
wlhm's Avatar
wlhm
Hi all,
I have a 2005 F350 cc 4X4 v10 with 48,000 miles and my truck dies while slowing to a stop. I let off the gas, and dead. It does not run rough, no check engine light, and starts right back up. This occurs 1 or 2 times in a several moth period. It may occur on rainy days? I can't recall exactly but from now on I will keep track. I have cleaned the MAF, and my fuel filter has been changed in the last 10,000. My mostly city driving mileage is around 10.5 to 11mpg so that seems ok.
There was a TSB #06-3-9 regarding this and I took it to FORD for a computer flash. Does this truck have an IAC and if so might this be the cause? Any help or suggestions would be great! Thanks
Old Dec 27, 2010 | 08:43 AM
BareBones's Avatar
BareBones
At 48,000 miles my first step would be to spray some cleaner into the air intake, especially on the backside of the throttle plate. Its probably just dirty.
Old Dec 27, 2010 | 10:38 AM
Fordfanatic4life's Avatar
Fordfanatic4life
i beleive teh 05 is drive by wire and has no IAC..
but i could be mistaken..
shame to cuz i would have thought to check the IAC first, hahahah...
Old Dec 27, 2010 | 10:57 AM
jh818's Avatar
jh818
Check EGR valve? Or your fuel pump?
Old Jul 27, 2011 | 08:54 PM
kingquad's Avatar
kingquad
Did you ever get this figured out? I have an 2006 that is doing the same thing only it is doing it quite often.
Old Jul 28, 2011 | 12:27 AM
wlhm's Avatar
wlhm
No fix as of yet, though I havent been working on it. I do know its fairly common and not big problem, just annoying. Check out the TSB in my first post. Good luck.
tntjacobs
3.8 & 4.2L V6
Sep 19, 2015 12:43 PM
2004_6.0 powerstroke
Oct 21, 2014 08:52 PM
bar M
6.7L Power Stroke Diesel
28
Aug 19, 2013 01:19 PM
IlliniJoe
17
Feb 17, 2008 06:07 PM
ccollins
Nov 22, 2006 06:56 PM
