Sponsored by: Real Truck
Overdrive Switch
Old Dec 26, 2010 | 05:19 PM
erniesshop's Avatar
erniesshop
Overdrive Switch
Has anyone done away with the overdrive switch on the gear shift , and used a dash mounted switch ? Good or bad idea???????
Thanks
Ernie
Old Dec 26, 2010 | 06:00 PM
1975StroppeBaja's Avatar
1975StroppeBaja
I haven't heard of anyone doing this mod. But, if you do it, one thing comes to mind.... try to maintain the illumination of the original switch. Reason being is that I believe the transmission trouble codes are displayed via flashing the "OD off" light.
Old Dec 26, 2010 | 07:22 PM
Fordfanatic4life's Avatar
Fordfanatic4life
why would you want to do that ?
i dont see how a dash mounted button would be convienent to use at all when you needed instant OD on/off shifts.
Old Dec 26, 2010 | 07:25 PM
erniesshop's Avatar
erniesshop
Because , I'm tired of changing out the gear shift lever !!!!!!
If I do it This Time......That will be #6 ? ? ?
Old Dec 26, 2010 | 07:27 PM
erniesshop's Avatar
erniesshop
I'm thinking of tieing in where the shifter plugs in.......That should leave everything else intact ??
Ernie-4
Feb 27, 2007 03:55 PM
ErnieL
Nov 1, 2006 01:40 PM
mwhz28
Car/truck Buying Advice
Feb 16, 2006 02:31 PM
1956MarkII
Dec 16, 2005 02:18 PM
Bigern822
Mar 2, 2003 10:59 PM
