Once I was trying to start my truck and managed to run the battery all the way down with the starter before I noticed that I had not turned the ignition switch on. I turned it on and rolled it down a hill to start it. 6V
Yup, every one of my trucks are wired like that. Also if you have the original solenoid there will be a button on the bottom of it so you can turn it over while you are under the hood.
Sorry, it's been 10 years since I messed with the wiring on my pickup. Amazing what I can forget in a short period of time. Glad you guys straighten things up for Joe..
just like the cars and they're grounded, so if the wire comes off and touches the dash. I had a problem 1 time involving working under the dash and a garage door....... from that point on I put a relay under the dash so it won't crank with the switch off.
