Starter button???
Old Dec 25, 2010 | 05:32 PM
Oakroadjoe's Avatar
Oakroadjoe
Starter button???
With the ignition switch off,key removed, if the starter button is touched,should the engine crank ? It is a 49,12volt system.
Old Dec 25, 2010 | 06:17 PM
mtflat's Avatar
mtflat
No, if it does somebody hotwired the button. It should feed thru the ignition switch.
abe's Avatar
abe
Yes,but it won't start... If you have in gear you can use it to move your truck a little bit...
Old Dec 25, 2010 | 09:19 PM
jb50F1's Avatar
jb50F1
I've got to go with Abe. I have the original 6V wiring and the starter button will engage the starter when the ignition is off.
Old Dec 25, 2010 | 09:49 PM
Doc's Avatar
Doc
Mine will crank as well. That is the reason I always leave mine in neutral when parked. I worry that my kids will find that button someday.
Old Dec 25, 2010 | 09:58 PM
-Jim G's Avatar
-Jim G
Once I was trying to start my truck and managed to run the battery all the way down with the starter before I noticed that I had not turned the ignition switch on. I turned it on and rolled it down a hill to start it. 6V
Old Dec 25, 2010 | 10:13 PM
fifty-two_f1's Avatar
fifty-two_f1
Yup, every one of my trucks are wired like that. Also if you have the original solenoid there will be a button on the bottom of it so you can turn it over while you are under the hood.
Old Dec 25, 2010 | 11:57 PM
mtflat's Avatar
mtflat
Sorry, it's been 10 years since I messed with the wiring on my pickup. Amazing what I can forget in a short period of time. Glad you guys straighten things up for Joe..
Old Dec 26, 2010 | 03:58 PM
Oakroadjoe's Avatar
Oakroadjoe
Thanks all for your help. Like some of you it has been a long time since i had a push button start .
Old Dec 27, 2010 | 01:12 AM
1oldtimer's Avatar
1oldtimer
just like the cars and they're grounded, so if the wire comes off and touches the dash. I had a problem 1 time involving working under the dash and a garage door....... from that point on I put a relay under the dash so it won't crank with the switch off.
Old Dec 27, 2010 | 10:18 AM
GreatNorthWoods's Avatar
GreatNorthWoods
If you push the starter button in my truck it blows the horn!
Old Dec 28, 2010 | 10:59 PM
lvin4jc's Avatar
lvin4jc
sounds like you're talking about your dd and it's a cheby
