Over the Summer, Oil Cooler failed on my 2003 F-250 4X4, 126K miles. Replaced it with OEM Cooler, Flushed the radiator, changed the waterpump. Was still seeing a high EOT/ECT differential, and truck runs great.
So in an effort to cure the problem with many folks including the dealership, giving me good advice I changed the EGR and temp sensor. Again OEM.
So now I drive around town with ECT almost always at 189-191 according to my scan guage. EOT is 208 to 215.
Now I hook up the 5th wheel, 9K and pulling down the interstate at 60 MPH in towing mode,,, and my eyes are on the scan guage,,,ECT 190-195,,,EOT 236 237 238.
I only pulled it 30 miles and truck ran fine,, but I worry when the EOT gets that high.
I am looking for some Ideas. One fellow told me that my timing could be set to high and the engine is running too hot. ( could that be a possibility)? and if so How would you check it?
By the way the Service dept at the dealership has no ideas., At least none.
My goal is to pull the trailer at 70 Mph, without hurting the engine by cooking the oil.
I do not have a coolant filter yet. I was trying to get the temps corrected before I installed one. I did follow Fords rec. flush procedures, simple green, distilled, vc-9 etc and the ect temps are perfect. I am using the Ford Gold .
The true differential is running around 33-35 degrees, when pulling the trailer. 20- 25 under no load.
There are no codes,, no guages out of range, no red lights
I don't burn bio diesel, and use centane boast every third thank.
I am concerned because the specs for the oil are 200-230 in the severe range and driving down the interstate getting high 230's is not good.
What are the eot/ect readings after the truck sits all night and before starting? If more than a degree or two the ScanGauge parameters are not set properly.
The eot reads 58/60 fluctuates, the ect is 58.7 constant. When I did all the flushing of the cooling system after the oil cooler change,,, I changed the thermostat also.
Going on the theory that your new oil cooler might be plugged again, I think you should install a coolant filter kit and run it for a month, or until it stops flowing, whichever comes first. Then open the filter and inspect. If you've got crap floating around, it will show up in that filter.
Can you rule out a bad thermostat brand new out of the box?
Or the wrong one?
Or it installed backwards?
Why not check if he is installing a coolant filter and opening it up anyways.
The thermostat on this thing isn't cheap, but for the price of a gasket and an additional 30 min of work... it may avoid doing a new oil / egr cooler and then finding it didn't do the trick because it was a bad thermo all along.
Forget the thermostat. Your thermostat only does one thing - control coolant temp. You don't have a coolant temp problem. If anything yours is a little lower than normal, which is just fine.
The oil is cooled by heat transfer to the coolant. For some reason you are not getting a good transfer, and lack of flow is the most likely problem, assuming all the sensors are being honest with you.
