shoot, I think so. I just got some to install, but my ac/heater box is removed..... do some engine search's on here, I'm sure you'll come across some pic's.
I just put Trick Flow Valve covers on my 460 and it took alittle lifting of the brake booster and ac box but popped right in. Only thing is if you put studs in you won't fit the cover. I put gasket maker on valve cover and let it set up with gasket attached, then installed, then put in studs. Hope this helps. Btw the valve covers I used are pretty close to 5 inches tall.
When you say "lift a little", could you achieve the lift by loosening the ac box and booster attaching bolts, or did you make some permanent mods to their attachment to the firewall?
Thanks for responding to my original post, and by the way, are you running Trick Flow heads on your 460? If so, which ones and do you like them?
I only meant that I pryed the booster up, as well as the ac casing. The valve covers dropped right on, then I put in the studs for the valve covers.
BTW the truck you are showing is a very sexy looking beast, one day my baby will look as good or better, but for now I am chasing a brake light problem. Happy New Year and Good Luck on all !!!!!!
Mine cleared the A/C box but not by much, you'd never get the valve cover off. I've got Hydro Boost for brakes so I couldnt say if it would clear the vacuum booster or not. I'm using L&L engine mounts by the way
