Electric Power Steering?
Old Dec 24, 2010 | 01:33 PM
bobwires's Avatar
bobwires
I've been having intermittent issues with my power steering pump. ....big surprise....
I'm a stereo guy by trade, and of the hundreds of remote starts I've done in the last year I've done several of the newer vehicles with electric power steering under the dash. A Ford Escape, for example.
Has anybody seen one of these models retrofitted to an old vehicle? I think I'd rather get one of these units and have a custom shaft go into the gearbox than any other method, unless somebody has reason to change my mind.
Any thoughts?
Old Dec 24, 2010 | 02:45 PM
mark a.'s Avatar
mark a.
Define "electric power steering". There are no street legal vehicles in the USA without a direct mechanical link to the wheels.
Old Dec 24, 2010 | 02:56 PM
bobwires's Avatar
bobwires
Electrically boosted, power steering. mechanical gear box, but instead of fluid helping it out, the shaft has a gear on it that is assisted by electric motor.
the technology has been around a long time, and is now starting to take off. it has potential in a lot of ways. The main thing for me is it's more efficient compared to the engine turning a fluid pump all the time. Also, they tie it into traction control nowadays for assisted steer when your front tires aren't gripping evenly and it pulls one direction.
Old Dec 24, 2010 | 03:00 PM
bobwires's Avatar
bobwires
here's a read on the safety end of things.
http://media.ford.com/images/10031/EPAS_MKS.pdf
I"m not sure if the system ford uses now is stong enough for a full size truck, or if you can make it work without the BCM and all the fancy stuff.
Old Dec 24, 2010 | 03:03 PM
bobwires's Avatar
bobwires
"EPS also won't work in HD pickups with recirculating ball power-steering systems. The parasitic load is too high for a 12-volt electrical architecture to provide enough torque. One possible solution to this issue is to apply some of the lessons learned from EPS to provide more intelligent hydraulic power assist that can vary boost levels based on driving conditions"
from this article -http://news.pickuptrucks.com/2010/05...p-trucks.html3
guess not...
anybody put a big rack and pinion on a dent? haha
Old Dec 24, 2010 | 04:15 PM
Nathan Plemons's Avatar
Nathan Plemons
Any chance you could use an electric motor to spin a standard power steering pump?
People are no doubt going to argue that this would be LESS efficient than driving the pump directly but I will argue differently. Electric water pumps free up horsepower because they have an impeller designed to flow well over a very small RPM range, and it turns at more or less a constant speed relative to engine RPM. A standard water pump has to work over a wide range of RPM's and is thus not extremely efficient.
You could use the same principle for power steering. Figure out what type of RPM you need to turn the pump at to provide adequate power assist and then find the most efficient 12v motor that could do it, assuming such a creature exist that could withstand continual duty.
Old Dec 24, 2010 | 05:06 PM
bobwires's Avatar
bobwires
Makes sense to me. Better yet, have an electric motor with a load-sensing circuit so it bumps up the pressure if you're turning hard. the thing would hardly have to run when you're moving.
Old Dec 25, 2010 | 07:26 PM
Mr Mayo's Avatar
Mr Mayo
Bring out the best!
I have been contemplating the use of a Toyota electric power steering pump on my '54 F100. They came in MR2 Spyders, all-in-one pump and reservoir. I don't know anything about how they are wired though.
Old Dec 26, 2010 | 01:17 PM
bobwires's Avatar
bobwires
that would be a very simple thing to wire. I like that idea - get a part that already exists on the market.
Ill look into the MR2's around here.
thanks
Old Dec 26, 2010 | 01:27 PM
bobwires's Avatar
bobwires
Toyota MR2 Power Steering System
mattymax
Oct 16, 2016 04:15 PM
mauicruza
1966 - 1977 Early Broncos
Feb 27, 2015 04:51 PM
jjpeach
17
Feb 22, 2015 10:35 PM
DIXIEDOG1
2009 - 2014 F150
May 28, 2013 08:55 AM
