Does a DP controller dim?
Dec 24, 2010 | 12:40 PM
Molon Labe
Either I screwed something up or I found a dimming feature that I dont know how to reverse....
I was arming the no start feature, when I decided I wanted to park somewhere else, I tried to unarm the tuner with the truck running, but ended up with a "C" showing I pressed the "-" and it went into stock mode and the light dimmed?
I tried to repeat what I did, but I cant seem to get it bright again?
The truck runs fine, and all the tunes are ok...
Anyone ever come across this?
Dec 24, 2010 | 12:52 PM
hmm I think I might have dimmed mine too. Let's see how this goes.
Dec 24, 2010 | 12:59 PM
Yes, you can dim and brighten the LED display. If you have your original paper work it should say how to do it.
Dec 24, 2010 | 01:19 PM
Molon Labe
Thanks Clay, I just looked at my paperwork and it sais nothing about dimming
Anyone have the directions handy?
Dec 24, 2010 | 01:30 PM
Quote:
Originally Posted by
Franko72
The directions refer to this as "Contrast", hence the "C".
Dec 24, 2010 | 01:39 PM
Molon Labe
PaysonPSD
The only parerwork I got was my list/order of my tunes.
"The notice" about changing tunes under load,
& "Recommendations" about letting it warm up before using the afterburners
Dec 24, 2010 | 01:58 PM
Here you go Frank.
Removed instructions for security of position 0.
Dec 24, 2010 | 02:02 PM
Molon Labe
Thanks you very much Robin...I didn't get that paper with my tuner.
Ill keep this for future reference...
Dec 24, 2010 | 02:10 PM
Franko72
MY PLEASURE
Please do, I may need it someday.
Dec 24, 2010 | 02:18 PM
THanks! I didn't get that either, had no idea I could dim the switcher and have always thought it's too bright at night.
Dec 24, 2010 | 02:19 PM
Just a heads up, I am not sure if Dp wants the no start info up on an open forum.
Dec 24, 2010 | 02:28 PM
Riffraff Performance
I was removing it as you were typing. Gone now.
If anyone needs those instructions PM me.
Dec 24, 2010 | 04:37 PM
I found a link on the DP site for the switch instructions in pdf.
LINK See bottom of page. Not such secret stuff after all.
Dec 24, 2010 | 05:13 PM
PaysonPSD
Huh, always seemed to be a hush hush thing in the years past.
Dec 24, 2010 | 05:18 PM
It's also posted on two different powerstroke forums that I found. Once it's out it's out. Pretty hard to get the toothpaste back in the tube.
tjmcb
Jan 10, 2014 11:22 PM
frhrwa
Aug 17, 2013 09:41 AM
aquaman
Oct 28, 2009 02:33 AM
1978fordf250
Feb 3, 2008 06:11 AM
Wizardvette
1997 - 2003 F150
Mar 7, 2005 12:30 PM
