Sponsored by: Auxito
Electrical...this has come up before I think.
Old Mar 6, 2005 | 12:14 PM
Wizardvette's Avatar
Wizardvette
Sitting at a light today, my radio came on by itself. The clock was dim until I turned off my headlamps. ??? I shut the truck off at the deli, and checked it again when I restarted. Still dim when the headlights are on. I got the radio to turn off, but the issue with the dimness is still there. Any clues? I remember something similar here a few months back.
Old Mar 6, 2005 | 08:03 PM
wezol5484's Avatar
wezol5484
Did you check the Dimmer Switch? Im sure you have. If I remember right, the problem was something like water leaking in through the windshield and getting behind the dash. Someone will chime in here that knows.
Old Mar 6, 2005 | 08:06 PM
Wizardvette
I would hope it's not a water issue. That's one of the reasons I got rid of my Wrangler.
Old Mar 7, 2005 | 05:58 AM
Wizardvette
Update...trip to work this morning....all functioned properly.
Old Mar 7, 2005 | 08:23 AM
Johns9163's Avatar
Johns9163
Sounds like a ground issue. Check your body grounds coming from the battery for corrosion.
Old Mar 7, 2005 | 11:59 AM
Wizardvette
I'll check as soon as I get home! Thanks!
Old Mar 7, 2005 | 12:30 PM
BillyBob69's Avatar
BillyBob69
Hmmmmm Everytime I turn on my lights, mine dims down so it isn't so bright in a dark cab. Or are you talking about even more than that?
mustangpt
13
Nov 26, 2014 02:39 PM
expoman55
Mar 26, 2013 07:12 AM
dirtjb18
Electrical Systems/Wiring
Jan 10, 2006 08:21 PM
edsf100
Dec 30, 2005 09:52 AM
Fordzilla1993
Oct 15, 2005 02:43 PM
