Sponsored by: Auxito
abs mod
Old Dec 23, 2010 | 09:15 PM
stso927's Avatar
stso927
abs mod
2002 f150 extend cab--5.4--twd-- abs codes stated front right sensor--didn't change it for about two years---changed it last week and now get abs mod. code---would not chnging the sensor for that long cause the mod. to go bad-have tried unhooking battery and resetting codes with scanner--light blinks one time then stays on---where is the abs mod located? thanks
Old Dec 24, 2010 | 04:46 PM
noonespecialer's Avatar
noonespecialer
its the Rear Wheel ABS module/sensor that mounts on the rear differential, I think. My ABS light was on, and I changed that sensor, after about six months of looking at that dash light. Light turned off, problem solved. Replacement was BORG WARNER at O'reilly's for $10.
jaoneill
Escape & Escape Hybrid
Jul 19, 2013 04:14 PM
spinella
Sep 10, 2011 03:51 AM
frank5
1983 - 2012 Ranger & B-Series
Nov 19, 2006 02:30 PM
JD in TN
Jan 19, 2004 09:38 AM
