according to the chart, you're right, 22a for 16ga and16amps for 18ga. I think a 5a fuse has a chance of blowing if the solenoid pulls a little more current than usual, as in every time it's dark, raining, cold, snowing or whenever you wear white clothing or a suit. A 15 or 20a fuse would still protect the circuit.
I'm saying don't fuse it at a higher amperage that the wire can safely handle or the wire becomes the fuse.
You shouldn't need more than a couple of amps to pull down the solenoid.
If you're so intent on jury rigging your truck it would probably be easier and cheaper to just run some zipwire up the PS fender, through the climate control area and across the dash to where you want it switched.
Drop a SPST-NO momentary switch across the end. (either button or toggle)
At the other end connect one lead to the S terminal of the solenoid and other lead to the fuseholder.
Connect the other side of the fuseholder to the hot terminal of the solenoid where the battery cable attaches.
At least if the wire is paired you only have to pull it once and it's less likely to become tangled.
Since you want cheap, buy some lamp cord at the BigBox, it should only be pennies a foot.
You're going from the same exact spot anyhow....
You can ALWAYS fuse 16Ga wire at 15A, just not the other way around.
Sure, Why not? Use some of the spool of 16Ga. speaker wire to trigger your starter.
