sd an comp. cam's
Old Dec 21, 2010 | 02:11 PM
88dually's Avatar
88dually
sd an comp. cam's
if lobe sep.,dur. an lift are almost the same between cam lines an manufact., why cant u get a 4x4 cam instead of sd comp. cam ? i dont exactly get it
http://www.summitracing.com/parts/CCA-CL35-231-3/
http://www.summitracing.com/parts/CRN-443902/
http://www.summitracing.com/parts/CRN-444232/
http://www.summitracing.com/parts/CCA-SK35-218-3/
these all say they work for early 69 to 96 an require valve springs, soooo,why not use this ?
http://www.summitracing.com/parts/CCA-SK35-242-3/
or
http://www.summitracing.com/parts/LUN-80351LK/
Old Dec 21, 2010 | 02:28 PM
Conanski's Avatar
Conanski
"Almost the same" doesn't cut it when you're dealing with an SD motor, LSA must be 114deg or more and intake duration 210 deg or less. Also if total valve lift is 0.500" or less valve springs are not absolutely necessary.
Old Dec 21, 2010 | 02:33 PM
88dually's Avatar
88dually
so the 1 crane cam is the only comp. cam with sd w/o getting a chip burned ?
6978sghfbjklgdfsjhkl
Aug 9, 2013 03:42 PM
UNTAMND
Feb 17, 2012 10:02 AM
USArmyTaterness
Jan 5, 2011 01:59 AM
Hitokori
Jul 16, 2010 11:04 PM
crescentwrencher
Jun 9, 2008 06:23 PM
