Stock Rear Diff. Temp Sensor
Old Dec 21, 2010 | 05:27 AM
throwdown's Avatar
throwdown
I can't seem to find what I need with the "search", so, can anyone tell me if I can install a temp sensor in the stock diff cover on my Dana 80? I am putting the new Eaton Tru-Trac in tomorrow and thought I would go the extra mile, if I can.
Old Dec 21, 2010 | 08:25 AM
mueckster's Avatar
mueckster
You can drill and tap the stock cover for the sender, but there won't give you much thread contact. I would prefer to add a NPT bung the proper size for the sender and weld it in. You could also use a nut that has been drilled and tapped to that size. Just a little added "security" in my mind.
Old Dec 21, 2010 | 08:32 AM
throwdown's Avatar
throwdown
That's what I was thinking. The weld I mean. Probably the best. Thanks
Old Dec 21, 2010 | 08:41 AM
h2guy's Avatar
h2guy
Years ago, there was a company out of Riverside CA, that offered a system of sensors (thermocouples?) 4, 6, or 8 each, indicator, & a rotary switch to switch between each of sensors. They were designed to be expoxied to whatever you wanted to monitor.
Worked well as long as you really cleaned the surface they were to be mated to when expoxying them.
While probably not perzackly accurate, they were really good for monitoring and noting any flucuations that were a precursor to trouble.
Herbward1
Apr 4, 2015 05:24 PM
A/Ox4
Jan 8, 2012 05:44 PM
bama29fan
Jul 23, 2010 12:56 PM
88stang1
Dec 2, 2009 05:27 PM
saltamontes
Mar 11, 2009 01:28 PM
