knocking engine
Old Dec 20, 2010 | 10:34 PM
superboy54's Avatar
superboy54
knocking engine
Hi, I need some help figuring out what is going on with my 69 360 engine. Today in the morning i started up and started knocking on the right side. So i let it warm up and the knocking stop. So later on i started up again and the knocking got worse. I checked the oil level and its full. So im wandering what could it be. I also took the spark plug wires one by one to check if it could be a piston or rod, but still kept knocking. Any ideas or helped will be appreciated thanks.
Old Dec 21, 2010 | 07:25 AM
71highboy1's Avatar
71highboy1
Talking
is it a manual trans?possibly clutch or throwout bearing.just my 2 cents
Old Dec 21, 2010 | 08:51 AM
PA74F250's Avatar
PA74F250
Maybe a bad lifter?
Old Dec 21, 2010 | 09:26 AM
kcw12's Avatar
kcw12
Pull the valve cover on one side and make sure all your rocker arms are tight.
if they are leave the cover off, with a towel or something (oil is gonna squirt) and start the engine and see if everything looks right.
Old Dec 21, 2010 | 12:43 PM
superboy54's Avatar
superboy54
my guess is a bad lifter too, cause it seems to smooth down ones the oil goes up.
Old Dec 21, 2010 | 01:09 PM
Victor L's Avatar
Victor L
Describe the knock a little better.
Does it make the sound immediately when started ?
Does it go away as soon as the oil pressure builds up, or how long does it take to go away ?
Has your oil filter been relocated ?
Does it sound like a deep thudding knock, or a light tapping, or a loud clapping ?
Does it go with engine rpm when you rev it a little ?
Old Dec 22, 2010 | 12:31 PM
superboy54's Avatar
superboy54
it starts when i start the engine, at first its a little loud tapping. then as the engine warms up and the oil goes up i guess it starts to smooth to a lighter tapping or sometimes it goes away.
Old Dec 22, 2010 | 01:30 PM
Danger_Dave's Avatar
Danger_Dave
Engine Noise Diagnosis 101
haha here u go the cure to all your problems, one of the best articles i ever read
Old Dec 30, 2010 | 12:03 PM
Danger_Dave
yes, no, maybe?
Old Dec 30, 2010 | 09:21 PM
Old blue 68's Avatar
Old blue 68
I had the same thing on my 460 it had hydraulic lifter and as soon as they pump up the sound went away
Old Dec 30, 2010 | 09:51 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
You could try Lucas oil additive.
I used it in all my VW air-cooleds to help with lifter tapping since they were solid.
Old Jan 2, 2011 | 03:40 PM
superboy54's Avatar
superboy54
Just did an oil change with thicker oil and it seemed to stop the tapping.
Old Jan 2, 2011 | 07:38 PM
Danger_Dave
hmm, watch you dont go with too thick of an oil. it is cold outside.
Old Jan 6, 2011 | 03:22 PM
superboy54's Avatar
superboy54
I used 40 is it ok considering its an old engine, plus i live in el paso tx, not much cold down here.
Old Jan 6, 2011 | 08:09 PM
cozadlance2's Avatar
cozadlance2
oil options. eek. lol. been there and still lost. Currently I just run 10w40 all year.
xaviar
Jan 28, 2020 12:45 PM
tjv01excursion
Modular V10 (6.8l)
99
Oct 23, 2016 06:48 PM
spudgunman
Apr 18, 2010 01:43 PM
ustolemycupcake
Mar 8, 2005 03:31 PM
RYCAN1
Mar 22, 2004 04:57 PM
