main/rod knock issues?
Old Apr 17, 2010 | 06:17 PM
spudgunman's Avatar
spudgunman
to continue a thread I had here https://www.ford-trucks.com/forums/9...sion-help.html
but has changed gears on the problem I started a new one for the new possible problem
I have a issue where at middle to upper RPM with no load only I have a VERY loud knocking high speed
Rod Knock, main bearing? i recently just replaced the head gasket due to blown. so possible relation to the bad oil causing this issue?
I was able to replicate knock in neutral by punching the gas at low idle or holding at about 2100 rpm but only at about 21-2500 RPM could I replicate, I can replicate at a park position with trans in N. this way
i just pulled the oil pan but dont know what I am looking for yet to know what is what. I can "wiggle" the bottom of every rod just a bit so dont know what that means...
what is the next steps and could this be my problem to investigating if this is the problem. and since the now have the oil pan off what should I check and repair while I am here?
Old Apr 17, 2010 | 08:47 PM
4x4 Bart's Avatar
4x4 Bart
The rods will wiggle a little, this is normal. Buy some plastigage and check the clearances on the rods and mains. Keep the caps in order and orientation. You may find the problem by just looking at them.
Old Apr 17, 2010 | 10:49 PM
spudgunman's Avatar
spudgunman
so 2 of them wiggle "the wrong way" by that I mean they wiggle different then the rest... I pulled them and the bearing was totally copper looking with deep groves in the shaft and bearing... i saw the 010 on them which someone said means it was rebuilt at one point so figured gone this far replace it ...
Old Apr 17, 2010 | 10:51 PM
mark a.'s Avatar
mark a.
Was it holding any oil psi ?
Old Apr 18, 2010 | 12:57 AM
spudgunman's Avatar
spudgunman
on the O of the OIL
Old Apr 18, 2010 | 10:13 AM
4x4 Bart's Avatar
4x4 Bart
Time to pull the engine and rebuild!!!!!!!!!!
Old Apr 18, 2010 | 11:41 AM
spudgunman's Avatar
spudgunman
yes the top end looks ok i have 150-170 lbs on the compression so I am just going to put a new crank in
Old Apr 18, 2010 | 12:04 PM
mark a.'s Avatar
mark a.
You can do that but it could turn into good money after bad. If there are rod bores that need resized you will just end up chewing the bearings right back out. Same goes for the main bearing bores, if they aren't straight, round & aligned anymore they will chew up bearings as well. This engine more than likely needs some machine work done on it, something has caused this. I would take it out get everything checked out and go from there that way you know for sure what your getting into.
Old Apr 18, 2010 | 01:43 PM
spudgunman's Avatar
spudgunman
I suspect a blown head gasket that caused bad oil caused it
alexk1091
Nov 22, 2014 06:46 PM
7636074460
Mar 16, 2014 11:00 PM
mechelement
Jan 14, 2014 07:39 AM
gearhead351
Oct 21, 2007 10:50 AM
