AIH resistor
Old Dec 20, 2010 | 06:01 PM
tdpower's Avatar
tdpower
AIH resistor
I finally got some 470 ohm 1/2 watt resistors for the ebpv solenoid plug and the AIH. My question is how to do the resistor for the AIH? I'm guessing that you just connect the resistor to the post with the blue wire and the other end to ground. I just wanted to make sure so I don't fry anything. Thanks for any help.
Old Dec 20, 2010 | 06:06 PM
Izzy351's Avatar
Izzy351
You go from the output side of the relay to ground...
Old Dec 20, 2010 | 06:11 PM
tdpower's Avatar
tdpower
Thanks Joe. That is what I thought. I guess you just leave that blue wire on that post connected?
Old Dec 20, 2010 | 06:37 PM
Izzy351's Avatar
Izzy351
I only removed the lead going to the AIH, so I guess so. I don't recall what color was what, so if you have pulled the lead off the relay going to the AIH already, you're good. Everything else should stay.
BWST
62
Mar 1, 2019 11:57 AM
rufushusky
Jan 8, 2013 04:11 PM
Atc210
Jul 11, 2012 09:25 AM
PsD007.3
Apr 18, 2010 10:16 PM
Pocket
45
Oct 24, 2008 08:08 PM
