AIH delete..Removed Solenoid, BLUE WIRE??
i deleted AIH and i also got rid of the solenoid that controls it..soo i removed the red and black wires completely from the truck..i did this cause i figured it was pointless to remove the AIH and leave the solenoid there just with 2 wires on it..i electrical taped all the wires and just tucked them down in the engine valley..i will only get a soft code correct??? i want to keep the solenoid off the truck should i just put a resistor on the blue wire and take it to ground to be safe?? and if soo what size resistor should i buy??
i already got rid of everything except the 2 wires i took off the AIH the solenoid and AIH and thrown away..removing that solenoid definitely cleaned the valled up a little bit..would just puttin a resistor on the blue wire and then the other end to ground?? an if i dont it wont ever set a ses light?? it will just throw a soft code correct?? i heard the resistor is 470 ohms 2 watts??
i guess what my question is..if i just leave the solenoid out and the wires all just electrical taped off and not put a resistor on the blue wire it will never throw a SES dash light will it?? it will only just be a soft code?? and it wont ever hurt if i have to run any type of dianogstics test??
BWST
62
03-01-2019 11:57 AM
ryanboisture
03-06-2016 07:01 PM
Backdraft-14
03-17-2012 05:16 PM
