Torqshift thermostat?
Old Dec 20, 2010 | 03:09 PM
gunnarGSD's Avatar
gunnarGSD
OK guys did a search the last few days but could not find anything specific to thermostat. After reading a thread from someone, somewhere I seen that their transmission temps were 160-170 degrees and I began to wonder as mine never ever gets that high. During the summer pulling my trailer it might get to 85-95. Today after driving around it was only at 50, but it is also 10 degrees outside. Coolant and oil temps come up fine to 188-192.
I thought I heard of a thermostat in the transmission, yes-no? If so I would say it is stuck open yes-no? And lastly can it be replaced relativley easy with a transmission service? Thanks guys
Old Dec 20, 2010 | 03:15 PM
bpounds's Avatar
bpounds
Are you using the Bully Dog to read OBD temps? If so, I wonder if the BD is reading the temp properly, and also wonder if your TFT sensor is good. A good check is to look at the ECT, EOT, and TFT in the morning before you start the engine. They should all be within a few degrees of one another. Make sure it isn't showing °C.
There is a thermostat, but your temps are so low that I'm not sure they can possibly be correct even if the stat were stuck open.
On edit:
85-95°C = 185-203°F
50°C = 122°F
Sounds likely that you are reading C.
Old Dec 20, 2010 | 03:57 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
He's in Canada...he WANTS it to read in C !!!! LOL
Hi Bill !! Merry Christmas......
Old Dec 20, 2010 | 06:10 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The thermostat is not easy to change. It's inside the pump body, so you have to remove the trans and then remove the pump. Tear down the pump and you'll find the thermostat.
Even if the thermostat were stuck open the trans would not run 85-95F. I agree that you're seeing degrees C, not F, and those temps are normal.
Old Dec 20, 2010 | 07:34 PM
gunnarGSD's Avatar
gunnarGSD
Yes I am.
Good point regarding the TFT.
I just looked now but the numbers might be skewed a bit as I have it plug'd in but get this. My ECT is 114, EOT 99 and TFT is 84...go figure 84?? It was not 84 this afternoon when driving and my ECT & EOT were at operating temps. This is after sitting for four hours in 10-15(F). I dunno
All the temps are indicating F
No I don't LOL
Thanks Mark. I'm thinking then the TFT sensor may be pooched, although I guess it is possible the Bullydog PMT could be reading it wrong. I monitor Pyro, EOT, TFT and ECT. All but TFT are within spec.
Thanks guys for the insight
Old Jan 18, 2011 | 05:11 PM
Kert0307's Avatar
Kert0307
Bumping this thread as I have a similar situation. I'm using a Bully Dog to monitor temps. My trans stabilizes at 40 degrees F. In the cold (less than 20 degrees f). If the truck is warmed up and I shut it off for about fifteen minutes, as soon as I start the truck the trans temp will be between 100f and 75f, as soon as I drive around it falls back to 40f and stays there...
Old Jan 19, 2011 | 08:43 PM
sullyt28's Avatar
sullyt28
Damn .... I use the bully dog also and seeing the same thing. Maybe something with these BD systems ??
Perhaps BullyDog Jason could chime in and shed some light on this ?
Old Jan 19, 2011 | 09:10 PM
Misky6.0's Avatar
Misky6.0
Gunnar, as a check - change your display back to use US units and
see if the 3 temps are now closer together?
In my scangaugeII, I have to manually program in the TFT info
in order to read it. So, "maybe" it would be wrong if I converted
to C vs. F? I know nothing about your BD, but if they pre-programmed
in the TFT - maybe there is a bug in the BD.
Or find a friend with another ODBII reader and have them check it.
My 6.0 sat over the 3 day weekend. low 50s to high 60s temps.
On Tuesday AM all 3 temps (ECT, EOT, and TFT) where all within
a degree or two of each other @ 7AM they were very close to
the reported outdoor temp (54*F).
It appears the TFT cools off much faster than the ECT/EOT temps.
Probably because the TFT doesn't get as hot as the other temps,
so it's always going to be cooler once things are shutdown and
allowed to cool.
Overnight, my ECT/EOT cool down and in the morning are nearly
identical (usually 1 or 2* delta) but they are still 10-15* above
the outdoor temp the next morning - they haven't had enough
time to completely cool off yet.
The TFT however, is almost always back to outdoor ambient temp,
because it was only 135* when I got home the night before.
Once summer temps hit, I'd be curious to see how low the temps go
when it's 70s @ night here.
Old Jan 20, 2011 | 08:59 AM
Kert0307's Avatar
Kert0307
Mine are all within a couple of degrees before the truck is started in the morning. Here is a link to my thread where I mentioned that when I added a winter front to the truck my trans temps went up to 90-100 degrees.
https://www.ford-trucks.com/forums/1...rans-temp.html
Old Jan 20, 2011 | 05:43 PM
gunnarGSD's Avatar
gunnarGSD
I have always had the BD monitor reading in farenheit I actually don't even know if it will read metric. I am going to have a transmission service here in the spring before I start towing again and I am going to have the dealer check the temp with their equipment.
Old Jan 21, 2011 | 07:29 AM
Kert0307's Avatar
Kert0307
I flipped my BD monitor to C last night to check it was around 60 deg F and went to 14 when switched to C, I don't think it's the gauge.
Old Jan 21, 2011 | 10:11 AM
seth1's Avatar
seth1
I doubt its any kind of gauge problem. I have insight and my trans temp won't get up to normal temp neither
24 Carat
Jan 22, 2016 07:35 PM
*STX*
2009 - 2014 F150
Aug 26, 2015 07:30 AM
Moose42
2004 - 2008 F150
May 23, 2010 08:00 PM
Catfish369
Oil & Lubrication
Oct 3, 2004 11:53 PM
carpe_diem
Aftermarket Products
20
Jul 31, 2003 02:13 AM
