Aftermarket Products
Sponsored by: Worksport
Running boards - yes/no?
Old Jun 5, 2003 | 09:15 PM
carpe_diem's Avatar
carpe_diem
I got this F350 and it came with running boards. What's the point? To keep the mud off the truck?
I am thinking of removing them as I think the truck would look more cool without them. I also don't need them to get inside the truck. Anything I am missing?
Old Jun 5, 2003 | 10:03 PM
desperado_18_2000's Avatar
desperado_18_2000
I'm not much for the flat running boards that you'd more commonly see on luxury vans and things.
The only way i'd want a pair of those on a truck is if it was a 2wd, for a 4x4 with a decent lift, i'd want step bars.
So i'd say i wouldn't keep them..
Old Jun 5, 2003 | 10:47 PM
Jim242002's Avatar
Jim242002
They just help shorter people or older people to get in the truck...And if it is 4x4 or lifted they help...But i don't like them at alll....I just jump up in mine....
Old Jun 6, 2003 | 01:10 AM
charlez's Avatar
charlez
I have them on my truck and would have to agree they aren't there for looks. I do like them overall. The main thing is that they save the paint. I can see where the previous owner didn't have them installed from new and the bottom of the door is covered with nicks and scratches from gravel spray. They are handy to stand on to reach the center of the roof (removing antennas and the like). If I were going for looks, I'd get some nerf bars and a good set of mudflaps to knock down the spray.
Old Jun 6, 2003 | 02:03 AM
carpe_diem's Avatar
carpe_diem
I haven't yet used the running boards on this truck.
From my perspective - cons:
1) you are carrying extra weight. While it is miniscule per gas tank, over the years, it adds up to something.
2) clearance is reduced. This is a 2wd but anyway.
3) it is harder to crawl under the truck if you need to look at something. Haven't really been affected by this yet.
Pros:
1) protecting paint. Don't know if I would worry about this, the truck is 13 years old.
Old Jun 6, 2003 | 01:09 PM
ggarrahan's Avatar
ggarrahan
I have them on my 2003 King Ranch 2wd, I like them because they keep people from dinigng the doors, they hit the running boards instead, and you really have to smack those hard to bother them!
Old Jun 9, 2003 | 12:03 AM
SouthernDually's Avatar
SouthernDually
Thumbs up Running boards - yes/no?
I have them on my 2x4 and love them. My paint stays nice and I do use them to reach up in the bed when needed. They also help protect the trailer behind me. Yes I am verticaly challanged but even if I weren't I would still have them. Just my opinion.
Old Jun 9, 2003 | 01:56 AM
Mil1ion's Avatar
Mil1ion
My running boards were the second thing I added to my truck.
I have appreciated them from day ONE.
They have saved tons of wear and tear on the truck
have you ever been surprised by having to drive on a freshly oiled road ?
I have, No oil ended up on the paint.
& The ladies love them.
Old Jun 9, 2003 | 09:10 PM
david.brady's Avatar
david.brady
Chicks dig 'em. That sounds good to me. I personally chose Nerf Bars but I think that depending on what you use the truck for and your vertical ascention. If you don't use the truck off the road much, clearance won't be a problem. If ya like 'em keep 'em, if not chuck 'em, things don't always have to serve a purpose, right.
Old Jun 9, 2003 | 10:25 PM
Duderoy's Avatar
Duderoy
I am 6'4" and I wouldn't trade mine for anything. Once your used to the first step it's so much easier. As for looks I think trucks look terrible with nothing there. Shouldn't be able to see the frame if you ask me.
Old Jun 13, 2003 | 03:24 PM
ford5.8's Avatar
ford5.8
I took the runners off and put nerfs on..
Old Jun 22, 2003 | 12:46 PM
FMC's Avatar
FMC
On my 79 F250 i built a set using scheduale 40 pipe3" dia. with 90 deg. elbows which i bought welded all to gether then used 1/2 " plate for the end cap which is bolted to the t case using the bolt holes for the t case and on the rear side i made a plate that matched 2 of the 4 holes on the frame rails with a backing plate inside the frame rails and on the top of the pipe as a step i had made was sheet checkerplate alum.and had it rolled over the side of the pipe to about half covering the pipe.then using 6 counter sunk screws i drilled and tapped the pipe to mount the checkerplate.it works it looks cool when polished and i can use them as a anchor tie down to use for a camper tie down,once i had a flat tire and use a fork lift under the pipe as a lift point to lift the truck to change the tire .I had no bending or flexing.i have a 3" body lift and it still looks cool .just my thoughts or idea. Paul
Old Jun 24, 2003 | 02:18 AM
Prodigy223's Avatar
Prodigy223
Exclamation Running boards - yes/no?
If your truck is a show truck or doesn't see much fourwheeling, then I would say keep them because they are nice when you want to get in your truck. If you do any off roading then get rid of them. They are the first thing to drag in the snow and the first thing to hit you you are driving over obstacles. So depending on how you drive, either keep them or chuck them.
Old Jun 30, 2003 | 10:31 PM
13hondacr250's Avatar
13hondacr250
I'm planning on jacking up my F-250 PSD to a towering height. I'm 6' but it will be a pain to get in. I don't grab the door or steering wheel on my lifted 150 cause it wears things out. I jump. What I want is these flip down foot ladders that are mounted inside the door and are about 15 inches tall folded up when the door is closed. Folded down there about 25 inches and have 2 steps. Problem is that there made for a Cessna 208 Caravan Airplane. So there going to be very spendy.
Tyler
95 F-150 302
94 F-250 PSD
Old Jul 5, 2003 | 11:16 AM
Karic's Avatar
Karic
c_d;
What kind of boards/truck are you running? You wanna sell them?I'm seriously thinking of a set for my S/C dually if the price is right.
Rick
