1996 F250 7.3 fuel pump removal trouble
Old 12-28-2010, 03:06 PM
BIGRED 7.3L's Avatar
BIGRED 7.3L
BIGRED 7.3L is offline
Originally Posted by armymanfo
I just got the new pump...and as for the tappet WELL its still in teh crank case hole...still not sure on how to get it out now. It seems like it craked from the old pump and stayed in there. AS for the fuel pump lifter...I just hope it hasent fallen into the crankcase.
Thanks for the welcomes and the ideas!
I am confused about what is actually wrong...did you break the bottom of the pump off in the hole or did you pull the pump out and the lifter/pushrod fell in the motor?
Old 12-28-2010, 03:34 PM
tekguy4's Avatar
tekguy4
tekguy4 is offline
after reading this a lil while ago.. went out and got pump out and it was broken identical to the one pictured earlier.. 99% sure that the oring was catching up on some built up crap in the bore and just hanging
Old 01-04-2011, 03:45 PM
armymanfo's Avatar
armymanfo
armymanfo is offline
The bottom of the fuel pump has broke off flush with the crank case. The fule pump is out but cannot get the nipple out of the crank case that holds the tappet. I tried to crank the motor (not by hand) and it didnt even budge...any suggestions on how to get that out of the crankcase hole?
Old 01-04-2011, 03:51 PM
Copedawg's Avatar
Copedawg
Copedawg is offline
HOLD on man! Don't even sneeze! This has never happened to me before....but I am sure it has happened to others just sit tight. Someone will help you out.
It sounds to me the tappet has fallen already. DON'T crank it any more.
Old 01-04-2011, 04:37 PM
BIGRED 7.3L
X2 on Copedawg's comment. if you can see the push rod sticking up then you know you are ok, for now. if not then it is in the motor somewhere. Until someone who has fixed this issue chimes in I would soak the piece with PB or what ever continuously until you get the answer. Don't crank the motor.
Old 03-02-2013, 11:02 AM
jastone502's Avatar
jastone502
jastone502 is offline
pump broke off in block
was gently working pump out of block then it just released and lower section with oring still in block. HELP !! how can I get it out !!
Old 07-27-2020, 07:58 PM
Ryan Foreman's Avatar
Ryan Foreman
Ryan Foreman is offline
Lost
Originally Posted by RÖENTGEEP
Also dont forget the blue fuel line in the front, and be very carefully because the pump could be broken
my lift pump broke exactly like this picture above how did you get that bottom part out BTW the plunger is broke inside the bottom piece
Old 07-28-2020, 11:36 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Arrow
There are a good link in the other thread you opened. good luck.
PS the pic I posted above its not mine, so I dont know how it went. sorry
jimzpsd
2017+ Super Duty
63
03-13-2020 01:51 PM
Patokik
08-18-2018 12:22 AM
jb10725
01-10-2015 09:58 PM
skidford
18
11-22-2007 08:28 AM
zero 2
11-04-2006 06:02 AM
Quick Reply: 1996 F250 7.3 fuel pump removal trouble
