Guess What???? 04 F350 NO START
Ok lets start
Checked all the connections under the hood and bought connection cleaner and still no start!
Unplugged sensor on passenger side.....no start
Unplugged sensor driver side that connects to exhaust....no start
Had both unplugged no start.
Checked batteries from when it quit and one was bad. replaced it ...... no start
Got the starter checked it is good ..... no start
All sounds that it made before it started under the hood are normal..... no start
RPM gauge never moves at all.............no start
Please help with any ideas of what to do next????????
Would anything dealing with glow plugs keep the truck from starting?
Have tired while cold and while its warm out.
__________________
__________________
have you tested the FICM yet? If not read here for directions https://www.ford-trucks.com/forums/8...procedure.html
How about removing the fuel filter on top of the motor and watch to see if the bowl fills up? there is a no start thread on here that will help you in figuring this out. Read through this https://www.ford-trucks.com/forums/8...condition.html
on
Check video so you can see what I am getting when I try to crank it!
YouTube - 04 Ford F350 Diesel No Start
