No spark/tst light question
Old Dec 27, 2010 | 08:40 PM
JimsRebel's Avatar
JimsRebel
Originally Posted by dogmantra
I am as confused as ever, but here are the readings. When checking power at the plug leading into the module I used the positive lead in the plug and grounded the negative lead to the frame. For all other measurements I placed the positive lead on the positive battery terminal and used the negative lead to test different points. I have my multimeter set to 20v DC.
First off...glad it was an easy fix that did not cost any more money.
To use your volt meter, attach the negative lead to the battery NEG (or any good frame ground) and use the positive lead to test at the different points. Ground is alway the reference point.
Really just glad it is working now.
Jim
Telestar
45
May 4, 2016 06:35 PM
mbolte
Nov 25, 2011 06:54 PM
the
Aug 6, 2011 08:59 PM
jejenkins417
Mar 14, 2011 01:57 PM
kjg26
Mar 14, 2005 11:01 PM
