Fuel Pump
Old Dec 22, 2010 | 01:58 PM
lwclark's Avatar
lwclark
I blew compressed air up the gas line at the fitting at the cab floor and "fixed" the clog. The pump seems very effective mounted to the frame rail within about 8 inches of that fitting.
Unfortunately now my carb's float doesn't float. I have a feeling I'm going to be sorting out this truck for a long time.
Old Dec 22, 2010 | 02:18 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Larry, don't get discouraged,probably just a piece of crud that dislodged and messing with a float,needle/seat,or fuel passage.I would bite the bullet,pull the tank.Take it to a good radiator shop,have it cleaned out,maybe seal it.I once bought a rebuilt carb after dealing with rust clogging issues,only to have this problem on the new rebuilt one.I cleaned the tank,had to clean and regasket my reman'd carb ,and had no further problems.
Old Dec 22, 2010 | 11:47 PM
lwclark's Avatar
lwclark
ibuzzard, you inspired me to give it another shot. A small adjustment to the flap near the float hinge pushed the needle a little higher and solved my problem! Thanks. I'm afraid you're probably right about the gas tank.
I like this forum.
Old Dec 22, 2010 | 11:53 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Glad you figured it out! Do you have a filter ahead of the pump? That will help until you can clean out the tank.
Old Dec 23, 2010 | 12:06 AM
ibuzzard's Avatar
ibuzzard
The family asks that, in lieu of sending flowers, you make a donation to the
Save the Curmudgeon Foundation.LOL!
Old Dec 23, 2010 | 07:55 AM
lwclark's Avatar
lwclark
Yes, a filter came with the Mr. Gasket pump. It screws right into the input. I think I'll move my clear filter in front of that one for easier diagnosis and replacement.
fightlivefree
Sep 17, 2014 09:52 AM
lbrauer
Aug 8, 2011 02:18 PM
budrizer
17
Jun 15, 2010 11:36 PM
Larry Murray
16
Apr 7, 2007 03:31 PM
Larry Heath
Nov 2, 2003 07:31 PM
