Bad Gas or Defective Fuel Pump
I have a 92 F150 XLT, 302 cu in engine with 4WD, 8 foot bed. I put in a Spectra Premium fuel tank assembly for the rear tank. I have 2 tanks on my truck: one in the front and one in the back that I replaced.
The symptoms when I switch to the rear tank are rough running, slight backfiring, poor power and acceleration. When I switch to the original Ford front tank it runs fine again almost immediately.
Question: Is it bad gas or a bad fuel pump? I suspect it to be the Spectra fuel pump because it is "made in China" as is the rest of the tank. It is only 1 year and 9 months old. I put in 3 cans of "Dry Gas" in the tank and can't see much of a improvement.
So how can I determine what the problem is? I guess I can drain some gas out of the rear tank and see if I have water in it. Is there a better way to determine if it is the fuel pump or water in gas?
Regards,
Larry
Regards,
Larry
Truck Guy99
I do notice the weather getting colder and that means temperature in the tank will be colder too so maybe the fuel pump was overheating. Don't know without checking the fuel line pressure.
Still it's hard to check the problem when the symptoms are absent.
So right now, I'd say water in the gas did it.
Regards,
Larry
josiewales
04-19-2019 02:48 PM
Ole Ruff and Ready
12-10-2010 01:18 AM
1988F1504x2
03-09-2007 07:15 AM
binkley
03-11-2003 03:47 PM
