Accelerator isn't communicating
Old Dec 18, 2010 | 12:10 AM
kbturnleft's Avatar
kbturnleft
I've got an '04 Super Duty and today it gave me a scare. When I tried to accelerate from a stop sign it stayed at an idle. There was no communication between the pedal and the injectors. I coasted into a parking lot, put it in park and then it responded to the pedal. I started it after parking for a half hour or so and it idled at a real low rpm. It came back to normal after a few seconds, then ran fine for the 5 miles or so to get home. It has done the no response thing once before. Anybody got an idea what the problem might be?
<!-- / message -->
<!-- controls -->
Old Dec 18, 2010 | 05:53 AM
npccpartsman's Avatar
npccpartsman
You need to get it code scanned. It could be a harness issue, injector issue (leaking) or an actual pedal issue. No way to know for sure Do you have the adjustable pedal feature on your truck?
Old Dec 21, 2010 | 05:16 PM
flyglas's Avatar
flyglas
Hi. I just had this on my 250, It was a bad wire in the shifter handle to overdrive button!! You can't buy just the wire or button??? Have to buy shift handle complete. Solved my problem.
sc6.0diesel250
May 5, 2012 09:05 PM
nyaristo
Jun 19, 2011 04:12 PM
kbturnleft
Dec 17, 2010 07:58 PM
jdstover
Jun 19, 2010 11:52 PM
rmwitt
Jan 5, 2010 09:03 PM
