switched to T-6
Old Apr 17, 2013 | 10:39 AM
Courtney Williams's Avatar
Courtney Williams
switched to T-6
Just switched to Rotella T-6 5w40, truck loves it. Its been a lot cooler here the last week and it starts right up like a champ in the morning, but I did notice a little white smoke.. very little and it clears up within a few seconds. You can barley even see it. Is this normal? FICM at 48 on start and back up to 48.5 while driving.
Seems like my EOT and ECT are always 15* apart until the truck is fully warm, is this normal, even creeps over 15* but only durring warm up. ECT is always higher.
When the truck sits all night 12+ hours the numbers are always the same or off by 1 or 2 between EOT, ECT, and TFT.
Old Apr 17, 2013 | 10:51 AM
daddykitty's Avatar
daddykitty
Temps shouldn't be a concern till you are at operating temp. The cold soak temps should be the same or close...no worries there.
Old Apr 17, 2013 | 11:00 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Depending on weather but there is often condensation in the exhaust. Ever notice a car with water slobbering out of the tailpipe at a traffic light?
As daddykitty said above, temp spread isn't a concern until your truck is fully up to operating temp. Check it like this:
TSB 09-8-3
https://www.ford-trucks.com/forums/a...3&d=1318287140
Old Apr 17, 2013 | 11:08 AM
Courtney Williams
Yeah I should have mentioned its almost like condensation, nothing like a car on a cold day. Just had the radiator flushed too and no leaks or coolant loss. Degas cap looks good too. Next project is to replace the heater core.
Old Apr 17, 2013 | 03:54 PM
Rusty Axlerod
My truck seemed to like the Rotella T6 also. Smoothed it out a lot in the mornings. In my case the FICM is good, the ICP/IPR is good and RevX helped a lot with idle quality on cold starts so I'm sure it's stiction. I may try cleaning my spool valves on the injectors this fall before the temps start dropping. But for now the Rotella seems to be working noticeably better than the Motorcraft Dino I was using before.
Old Apr 17, 2013 | 05:13 PM
BLADE35's Avatar
BLADE35
You can undo heater supply and stuff a Hose in it
Didnt they turn the heater on for the flush????
Old Apr 19, 2013 | 10:31 AM
Courtney Williams
I'm not sure if they turned it on or not. It's not his first rodeo but I wasnt't here either lol.
The heater works fine, but I have that sweet coolant smell in the cab, and have had that for a while now. Before I did the flush.
Old Apr 19, 2013 | 10:39 PM
BLADE35's Avatar
BLADE35
Do you have Coolant loss??
Have you tried new Coolant cap??
Old Apr 22, 2013 | 03:23 PM
Courtney Williams
No coolant loss that I can see and the cap looks just fine.
Old Apr 22, 2013 | 05:58 PM
69cj's Avatar
69cj
Sounds like your good to go. Just keep an eye on the deltas after the engine is totally heat soaked. Usually about 20 miles at highway speeds. Could be longer with colder ambients.
Old Apr 22, 2013 | 06:04 PM
Courtney Williams
Yeah I towed a pretty heavy load this weekend up some hills and its was usualy around 10 or so at the most.
Old Apr 22, 2013 | 08:21 PM
jdw1's Avatar
jdw1
This says the coolant runs 15 degrees warmer, is this correct or a misprint?
Old Apr 22, 2013 | 08:29 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
While the truck is warming up, coolant will heat up faster than the oil. The difference between ECT and EOT only matters once you're up to operating temperature of ECT>=190*. So any difference, 15* or greater, where the ECT is GREATER than oil temp while LESS than 190* doesn't matter. If you're seeing ECT never get to 190* but EOT climbing up to 190*+, it's probably a thermostat issue.
Old Apr 22, 2013 | 09:00 PM
jdw1's Avatar
jdw1
Ya, I see what he is saying now, mine does the same thing.
Old Apr 23, 2013 | 09:50 AM
Courtney Williams
I couldn't get up to 190* and changed my T-stat and that fixed the problem.
jasenford89
1997 - 2003 F150
30
Jan 10, 2018 01:04 PM
Barret88
Jan 25, 2014 07:02 PM
mdula
31
Dec 10, 2010 10:29 AM
imsorope
1983 - 2012 Ranger & B-Series
15
Dec 18, 2005 12:22 AM
muscletruck7379
1978 - 1996 Big Bronco
Feb 14, 2004 07:57 PM
