wow ! thats what i call good feed back thanks . i have been wrenching all day 12 hrs but im glad you guys answerd cause now is a good time for me to do these as today i did both sides glow plugs / uvch / vc gaskets / ccv mod / tourqed every thing under vc and cleaned every thing ! all i got left to do is pull intercooler and clean it tomorrow . but i couldnt assemble the pipes i need a oring ! first out of turbo into spyder . all you guys here helped me learn . everything was loose under vc / tons of oil in tubes / one side of uvch was cocked open / 7 out of 8 glow plugs wide open / o ring under doghouse blew out / courious how much oil in cooler .
what do you guys think about pluging the hole in the back of the vally to save my clutch from oil and fuel baths !!! twice now .
thanks wes
[what do you guys think about pluging the hole in the back of the vally to save my clutch from oil and fuel baths !!! twice now .
thanks wes[/quote]
just got off clays site and got the oil x and went ahead and got air filter kit to christmas stuff for me . i know its bad to ship now and i couldnt live any farther at least in usa . but i got faith clay! thanks guys ! wes
Really new here, so I could be wrong, but I don't think your description as I read it is not 100% correct. My understanding is the #8 cylinder is oil deprived as the #6 fires right before it. The oil pressure is what tells the injector to fire, the #8 Long Lead injector takes a double sip of fuel to compensate for the oil pressure issues. But since the #6 fires right before #8 the oil pressure is a little low and can lead to problems with #8 injector.
The HPx does even out pressures across the heads, and allows #8 to get a little more pressure.
My comments are based on our discussions, so if something is amiss please let me know. I want to learn here, nothing more.
here is the basics of a long lead injector which is the stick thats in the #8 hole:
#6 fires right before #8, and #8 was starving for fuel, and clattering.
"long lead" means the injector stays open a fraction longer, giving it a better chance to fill with fuel, and run quieter and smoother. Ford claims it was for customer satisfaction only, and didn't affect emissions or longevity of the engine when they swapped out the #8 for the AE longlead.
the regulated return or frx fix's the dead head fuel rail and supplies the head from the rear port instead of the front port (atleast in my dieselsite regulated return) so #8 is no longer starved for fuel.........
"long lead" means the injector stays open a fraction longer, giving it a better chance to fill with fuel, and run quieter and smoother. the regulated return or frx fix's the dead head fuel rail and supplies the head from the rear port instead of the front port (atleast in my dieselsite regulated return) so #8 is no longer starved for fuel.........
It is worth noting that the "long lead" (AE) injector is not in all engines. Some have them, some do not. I guess it was a "game day decision" of sorts.
TSB 03-21-39
ENGINE - 7.3L DIESEL - ENGINE KNOCK OR "CACKLE" - 1999-2000 SUPER DUTY F-SERIES AND 2000 EXCURSIONS WITH ENGINE SERIAL NUMBERS 661894 THROUGH 1311240 - ALL 1998-2000 E-SERIES WITH ENGINE SERIAL NUMBERS 661974 THROUGH 1311240
NOISE - "CACKLE" OR ENGINE KNOCK - 7.3L DIESEL - 1999-2000 SUPER DUTY F-SERIES AND 2000 EXCURSIONS WITH ENGINE SERIAL NUMBERS 661894 THROUGH 1311240 - ALL 1998-2000 E-SERIES WITH ENGINE SERIAL NUMBERS 661974 THROUGH 1311240
TSB 03-21-39
Interesting reading. My serial number is 1035221 and it did not have the long lead injector. I think I read a thread a long time ago with some info from someone who was on the assembly line where the engines were made and it was pretty interesting info. I will try and dig up that thread...
Ive got both FRX and HPX done,the crackle that you hear when you first start up has gone and my truck has a much quieter smoother idle now,doesnt sound like a V8 mack at idle,but does when the hammer is down
So I am considering, after Christmas, the FRX and HPX but I will also be putting in a new fuel pump or rather an Air Dog. My questions are these
1 How is the fuel mileage with the FRX and HPX?
2 With the Air Dog do need the FRX/ would it be worth me spending the money on it?
3 How much more efficient does would/would the motor run with the HPX, FRX, Air Dog and in-tank mods done?
thanks
1) You may not see a big change in the MPG's. The motor will idle much smoother and run more efficient, so that is the big pay-off.
2) The Airdog does remove the air from the fuel by design. The FRx does eliminate the dead head issue, and provides a solid flow of fuel in the heads, so that is helpful IMO.
3) Having clean air bubble free fuel is critical to maintaining the efficiency. If you do those mods, you will all but eliminate the chance of air going through your injectors. The in-tank mods will eliminate the screens that get clogged, and help eliminate the air being sucked in. The Airdog will filter and remove any air that could be in the fuel. The FRx will keep the injectors supplied with stable fuel for the burn. I would think you would see a noticeable difference in the sound and you may even feel a power increase depending on how much air you get in your fuel now. And since it is more efficient you may even see your MPG's go up, if you are watching them closely.
