Need help with brake lights
Old Dec 21, 2010 | 08:46 AM
ronzzzy's Avatar
ronzzzy
I got a 2000 F250 with the diesel and 6 speed. All my lights work, but when i hit the brake pedal the brake lights dont go on, and the ABS light is on, on the dash. I just finished fixing the pushrod and the clutch master cylinder. The brake lights where fine before i fixed the master cylinder. Is there something under there i could of broke or screwed up while while fixing the clutch problem? I tried searching, couldnt find anything. thanks
Old Dec 21, 2010 | 10:07 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Your brake light switch is up under the dash in the general area where you were at when you were working on the clutch rod.
Old Dec 21, 2010 | 12:12 PM
ronzzzy's Avatar
ronzzzy
ok thanks, its was just loose, plugged it back in. at least it was an easy fix, didnt have to chase wires.
Old Dec 21, 2010 | 12:16 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Ok good, glade you got them fixed. Kinda need them!!!
Old Dec 21, 2010 | 04:26 PM
orng1's Avatar
orng1
I had that go bad and replaced it with a part from oreily's. They are idiots though so it helps if you have the part off to show them.
