its not a ca emissions truck, thank god. I'll try the screw driver idea and see if that helps if it happens again. Im also thinking that my GP's might be bad, probably not all of them, but some of them.
35 seems awful warm for a truck not to start due to a GP issue. Especially with repeated attempts and gray smoke. I'd buy it if it were in the 20's and was pouring out white smoke, but 35 and gray smoke I'm not so sure.
Hopefully I'm wrong on this and you can just lay a screwdriver across the GPR.
Thats what I was thinking too, but it was a lot colder than that last night and most of the day. We'll see here in a bit if it starts after being plugged in.
Oh and there was quite a bit of smoke. When I say grey I mean it wasnt dark, and it wasnt white. It was kinda in between. but there was enough smoke that it continued to smoke out of the tailpipe for about 2 or 3 mins after i stopped trying to crank it.
Chris- and that is why you're thinking oil? The cool temps are enough to impact oil injection but not enough to cool the air for the GPs to work?
I thought he wrote white smoke, but grey is what he posted. So, doesn't that indicate partially burnt fuel due to insufficient air, over-fueling or the truck is chipped/incorrect tunes. If it worked one day and not the next there should be an environmental change, which the PO listed as temps.
Oil could be in there as a cause for partial burn, right?
oil is getting close to time for a change. Almost at 3000. I need to check the level, but last time i checked it it was fine. Hopefully it'll start right up as soon as I go try to start it
My truck typically starts on the first crank above 32° and as temps get colder it requires multiple cranks to start. At 13° one morning this week it took 6 or 7 cranks. It has never failed to start. I limit my cranks to a few seconds each.
Oil can affect a lot of things, but smoke coming out the exhaust is a sign the injectors are trying to fire, which is a good thing. If the injectors are worn, the poppets inside tend to "stick" for lack of a better term so the injector is not actuated and does not fire fuel. In moderate temperatures, not having all injectors fire during cranking can cause a no start or hard start condition. Usually followed by a little rough idle during warm up, then things seem to be fine when it's warmed up since all the injectors start working again.
Edit: and I run my 15w-40 oil to 5,000 miles every time so it's not too old at 3k. Just make sure it's topped off.
You might try installing a GPR LED indicator light, to tell you when your GPR is ACTUALLY getting power from one side of the relay to the other. I put one on my truck, and it was invaluable when i started experiencing the same issues you have- cold temps, wouldn't start, even though the WTS light was on. Until i had a chance to get a new GPR, I would just jump the relay with a piece of battery cable to get it started. The LED saves a lot of guessing.
Another thing to consider is your starter. If it is dragging, it may not be turning the engine over fast enough to start it when it is cold. If the engine is warm, then it does not have to spin as fast to get the diesel hot enough to ignite. I had a problem with a starter for a while. Since the starter gradually got worse, I did not realize until it went out completely and I replaced it exactly how much slower it was turning the engine until I got the new one installed
You should be able to watch your volt gauge to see if the GPs are drawing power. Turn the key on and watch. When GPs turn off the voltage rises. This is how I knew a new Napa GPR was hit and miss. Also, I have to run syn oil in mine when it's cold out. I get terrible romps and hard start with dino oil.
