Hard Brake Pedal?
Old Dec 16, 2010 | 12:11 AM
luckyjoe's Avatar
luckyjoe
Hard Brake Pedal?
Got in my truck (77 F100) to go and get some firewood last week and did'nt have any brake pressure.....well a bare minimum and I had to lean on it! After a damn near heart attack, and 15 minutes of nursing this thing down the road, they finally came around. It's darn near a daily driver and I've never had a problem before it turned into Siberia around here. I have no leaks what so ever and it's full of fluid. Was it common to have problems with the booster? I've heard there is a check valve for vaccum on it that can stick occasionally. Any suggestions?
Old Dec 16, 2010 | 07:21 AM
Justin's Green Truck's Avatar
So, was the brake pedal just going all the way to the floor? And you had to push harder on the pedal to get the same braking effect as before?
Old Dec 16, 2010 | 12:14 PM
79FordBlake's Avatar
79FordBlake
Frozen water in the lines maybe? Would probably be a good idea to bleed the brakes and get some new fluid flowing if that hasn't been done in a while.
Not really understanding if you had to push really hard for the brakes to work or if the pedal was falling to the floor.
Old Dec 16, 2010 | 01:17 PM
luckyjoe's Avatar
luckyjoe
The pedal never went to the floor. It was just extremely hard to press before I could get it to slow down. Sorry for the confusion?
Old Dec 16, 2010 | 01:20 PM
Yea, id probly bleed the brakes like mentioned earlier and also look for vacuum leaks. Im not familar with a check valve for the booster but il look into it.
Old Dec 16, 2010 | 01:24 PM
79FordBlake
I am use to having to push firmly I have one truck that doesn't have power brakes, lol. Doesn't have power steering either.
Old Dec 17, 2010 | 01:52 AM
luckyjoe's Avatar
luckyjoe
I had a 76 F100 I drove for 24 years with no power brakes or steering as well, but I never had to get on a brake pedal like I did this thing! It was like pushing a brick wall with your foot. Going fast ain't no problem, but I like to slow down when I need to? It's a bad feeling when you can't......trust me. Already beat cancer once, I don't need to see a cardiologist this soon. Thanks for the help
Old Dec 17, 2010 | 07:04 AM
Have you determined anything yet?
Old Dec 17, 2010 | 10:58 AM
gcfisher75's Avatar
gcfisher75
I had the same problem in my 77' when it was cold the booster wouldnt work...run the truck for a while and the heat off of the engine would warm things up and it would work... I scrounged up some parts from a lincoln and put hydroboost brakes on and the difference is UNBELIEVABLE! I love my hydroboost brakes... for example... now keep in mind they werent working like they should b4 the conversion but after i put the HB on I had a 3,000lb trailer w a 9,000lb skid steer on it and i stopped (not using trailer brakes) better with all that weight then i did with just the truck b4. Totally night and day difference... But besides me getting excited about the hydroboost, I believe your problem lays in your booster and its probably just as easy to replace it...
Old Dec 17, 2010 | 11:03 AM
luckyjoe's Avatar
luckyjoe
Not yet. I've resorted to driving my 4runner until tomorrow, and can get to a relatives shop (he's got a lift) and see. I'm almost convinced it may be water in the lines. I actually got in it this morning and drove it, and it worked just fine. I'm still not going to take any chances and assume anything until I see for myself. I'll let you know. Thanks
Old Dec 17, 2010 | 11:31 AM
It's been a tad warmer in NC the last day or so than when the problem showed up hasnt it? I know it has in North Ga. Still cold, but a little warmer. You may be right, couldve been frozen water in the lines if its better now
truckfella
Modular V10 (6.8l)
17
Mar 16, 2020 11:59 AM
Dano78
Nov 27, 2016 07:44 PM
fordboy300
Jul 29, 2016 04:51 PM
autox65
1978 - 1996 Big Bronco
Oct 6, 2015 04:57 AM
whjco
May 14, 2010 04:59 PM
