Brakes sticking?
Old Jul 29, 2016 | 03:21 PM
fordboy300's Avatar
fordboy300
Brakes sticking?
Hi guys, I've had this problem for quite a while now where the brakes are really sensitive. The truck will sit overnight or for a couple days and I go to drive it and the brakes stick I should add its only the rear brake shoes. I have adjusted and adjusted the rear shoes also the parking brake cables are disconnected so I know it's not that. After a mile or two of driving the brakes dont hold the truck back anymore.
Any ideas?
Old Jul 29, 2016 | 04:12 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Are they adjusted to tight ... Jack the truck up when cool and see if they turn without dragging.
Bad rubber hose can also cause issues like this.
Also if the Master Cylinder push rod/pedal etc... is not allowing the master cylinder to return all the way home it won't release the rear brakes. The pushrod should have a tiny bit of slack in it.
-Enjoy
fh : )_~
Old Jul 29, 2016 | 04:51 PM
FuzzFace2's Avatar
FuzzFace2
When was the last time the drums were pulled?
This is a sign of brake fluid getting on the shoes.
I would pull the drums, pull back the rubber cups on the wheel cly looking for wetness. If dry and all looks good replace the rubber hose, bleed system, adjust drums and see what happens.
If still an issue look at the master for piston sticking. Can't see the rod needing adjusting if it was ok before but a pedal that does not release all the way can cause issues.
Dave ----
Neonfrog
1997 - 2003 F150
Apr 20, 2016 07:30 PM
hossfly1961
Oct 5, 2011 06:34 AM
byron74f100
Apr 20, 2010 02:25 PM
jux
Oct 16, 2005 03:41 AM
dynamic
13
Nov 21, 2001 09:38 PM
