restore
Old Dec 21, 2010 | 12:34 PM
  #31
dmeyer 351 4x4 rebel's Avatar
and its going to be a dd but i wont be scared to take her in the mud
Old Dec 21, 2010 | 12:41 PM
  #32
and i forgot to tell u that i will be pulling the trany out and having it rebuilt so well the motors out any thing i should do to it spark plugs and other **** ?
Old Dec 22, 2010 | 12:40 PM
  #33
think i mit go with the rc 6" lift a bit cheaper and than il have more money for other stuff to do and iv all ready installed a rc lift be for
yo last nite pull out 14000 lbs form snow and mud btw it was a chevy lol chevy surban and car on trailer lol
Old Dec 22, 2010 | 11:49 PM
  #34
**** it not sure i met also do a three inch body lift also y not lol
Old Dec 23, 2010 | 01:46 AM
  #35
hav24wheel's Avatar
hav24wheel
So u plan on a 6 inch suspension lift, and a 3 inch body? How big of tire do you plan on running again?
(I have a 4 inch suspension and 3 inch body lift on my wheeler n run 44s)
Also, cheaper lift isn't always better. The Tuff Country lifts have the most adjustable components in them. As in, it makes alignment a breeze!
Also, if wheeling of any kind is on the "to do" list I would recommend bracing up the axle pivot drop brackets.
Old Dec 23, 2010 | 06:59 AM
  #36
L. Ward's Avatar
L. Ward
Unless its super low mileage, as long as the motor is out I would go and do at least a basic quickie overhaul on it (gaskets, rings and bearings) a cam and headers wouldnt hurt either
Old Dec 23, 2010 | 11:25 AM
  #37
it just hit 130k so i plan on doing some of the motor work before puting it back in and 4 the size going 35s till i put the b lift in if il have money left over then prob get some 38s
Old Dec 24, 2010 | 11:44 AM
  #38
back to the drive shafts every one i talked to said i have get long driveshafts
Old Dec 24, 2010 | 12:52 PM
  #39
raptor1971's Avatar
raptor1971
My has a 6 inch lift with stock driveshafts and I did not drop the transfer case. Go to what lift kit you want to use web site and they will usely have the instruction on how to install the lift and what is included.
You can look them over to see what else you need to get. Some do not come with the drop pitman arm, shocks, brake lines, adjustable alignment bushings and all the little extra.
Old Dec 24, 2010 | 01:20 PM
  #40
ya it dont say nothing about the drive shafts
Old Dec 25, 2010 | 06:03 PM
  #41
got my ball joints and tie rod ends ha
areoseek
Feb 21, 2014 05:44 AM
alwaysempty
New Member Introductions
Apr 18, 2013 03:42 PM
mudder460
Sep 1, 2010 05:29 PM
4x4cody
Feb 17, 2010 12:27 PM
lt
Feb 27, 2002 01:05 PM
