4x4 vs. 2x4 engine perches
Old Aug 30, 2010 | 09:39 AM
mudder460's Avatar
mudder460
I got talking to a friend about my engine swap I am getting ready to do. I told him how I am pulling a 351w from a 2x4 truck and putting it in my 4x4. I said how I was going to buy a set of perches from a guy for a 351m 4x4. My buddy said I could use the perches from the 2x4 to put in my truck, but I told him the 4x4 were different from the 2x4. So are the perches for a 351m 4x4 the same as a 2x4?
Old Aug 31, 2010 | 10:19 PM
lostinfords's Avatar
lostinfords
2wd 351m mounts bolt to crossmember of 2wd which is NOT there for 4wd
78 f250 4wd w/ 351M red marks show where mounts bolted and the lack of the 2wd crossmember
Old Sep 1, 2010 | 12:29 AM
dw_wanno's Avatar
dw_wanno
The 2wd perches will not work as lostinfords was saying since the frame cross member is in front of the engine. Is this for your '77 F-150? Reason why I ask is that you will be looking for 351/400 perches from another F-150 4wd only. The F-250 perches will not work as they have a different bolt spacing. Also I can't remember if there is any differences between the F-150 perches from year to year. As for the motor mounts I went and purchased some for an early 80's 4x4 with a 351W. If your truck has a 300 I-6 you'll need different perches, but the bellhousing will bolt up. If you have 351/400M the perches should be the same, but you'll need diiferent trans for a small block ford. Hope this helps.
Old Sep 1, 2010 | 09:14 AM
alxsnmr's Avatar
alxsnmr
Which part of the bellhousing are you referring to? The 300 bell is not the same as the 351M/400 after the early 70s, when the 400 had a dual bell bolt pattern. If you mean that the manual trans will mate to both the 351M/400 bell and 300/Windsor bell then yes it will interchange.
Old Sep 1, 2010 | 12:10 PM
dw_wanno's Avatar
dw_wanno
What I meant is that the 300 uses a small block ford bolt pattern for the bell housing which is the same pattern as the 351W that mudder460 mentioned in his post that he wants to install.
Old Sep 1, 2010 | 05:29 PM
mudder460's Avatar
mudder460
Thanks guys, I know the bell is the same and I knew the 150 and 250 perches are different. Now another question is, will the z-bar pivot bracket that attaches to the bellhousing from a 351m fit on my smaller bellhousing?
Justin Braun
Mar 14, 2017 03:53 PM
grinnergetter
26
Jun 21, 2016 12:34 AM
bsiebert
Jun 18, 2016 12:27 PM
Xcr600man
Ford Truck Parts for Sale
Jan 9, 2016 11:28 PM
77FordDW
Engine Swaps
Nov 11, 2008 07:25 PM
