Sponsored by: Real Truck
steering locks up while driving!!! please help
Old Dec 15, 2010 | 09:54 PM
going strong ford's Avatar
going strong ford
Cool steering locks up while driving!!! please help
while driving my 01 f350 on the freeway the steering locked up on me only for about one second, the second time it happen i lost the brakes as well, i replaced the hydro-booster and everything was fine for about three days, now the steering is acting up again, it feels as if i turned the truck off but i still have brakes, any ideas
Old Dec 15, 2010 | 10:18 PM
KoolAidMan888's Avatar
KoolAidMan888
I had that happen once on my 92 7.3....... it got real tight and a day later the belt broke.... never did it again check that out
Old Dec 16, 2010 | 05:33 AM
lari250's Avatar
lari250
I had something like this happen too, Turned out to be a u-joint in the front end seizing up, just got worse, everyone suspected ball joints
Old Dec 16, 2010 | 11:51 AM
going strong ford
@lari250 did you see any wear on the u-joint? @koolaidman did you replace anything else? Thanks
Old Dec 16, 2010 | 12:15 PM
thomabb's Avatar
thomabb
I had the U-joint thing also. No visible indicator they were bad. Mechanic deemed them good 3 times before he caught it when it was stuck.
Old Dec 16, 2010 | 02:59 PM
sandrat's Avatar
sandrat
The thing about losing the brakes scares me though, sounds like a hydro boost fault if you lost both at the same time. Pump?
Old Dec 16, 2010 | 10:26 PM
KoolAidMan888
no i just replaced the belt and it was all good after.. just check to belt make sure theres no rips tears,, make sure the groves on the under side are in good shape
Old Dec 23, 2010 | 08:44 PM
going strong ford
thanks everyone, a couple of days ago I replaced the powersteering pump and it's been working just fine. I guess I should have said that my truck has 170,000 miles, I am the third owner and I thinks it's on it's third pump. Again thank you all
Old Dec 23, 2010 | 09:19 PM
KoolAidMan888
NIce buddy. Lets hope that was the problem. Good Luck.
The KoolAidMan
SultanGris
6.7L Power Stroke Diesel
41
Jun 22, 2017 10:43 PM
Joblues38
May 21, 2017 01:59 AM
utahstroke
Mar 5, 2017 08:18 AM
sleek122
Apr 9, 2016 12:51 AM
garbadee
Aerostar
13
Nov 18, 2012 09:56 AM
