2000 Lincoln Navigator antifreeze flush from eninge and radiator
Old Dec 15, 2010 | 03:15 PM
Haroon's Avatar
Haroon
I am going to change my thermostat and flush the antifreeze from my truck this weekend. My question is how do I get the coolant that is in the engine out completely?
Old Dec 15, 2010 | 03:57 PM
alloro's Avatar
alloro
Run a garden hose into the opening the t-stat fits into. Then disconnect the lower radiator hose and run the water until it comes out clear.
Do the same with the radiator and heater hoses going to the heater core(s).
Once all coolant has been flushed out, use compressed air, a vacuum set to blow, or whatever you have that will blow air into the t-stat opening, radiator, and heater hoses in order to force the water out. Once the majority of the water is out, put it all back together, add the correct amount of antifreeze, then top it off with water.
Old Dec 16, 2010 | 03:46 PM
Haroon's Avatar
Haroon
Where is the Heater Core(s) located?
Old Dec 16, 2010 | 08:58 PM
c_hohensee's Avatar
c_hohensee
The front heater core is inside a plenum box behind the dash. The hoses run through the firewall. If you have a rear heater it is inside the drivers side rear of the truck behind the trim panel.
Old Jun 30, 2025 | 06:47 AM
sbilby123's Avatar
sbilby123
It is my understanding that, correct me if I’m wrong, but when refilling the radiator etc after a flush , coolant concentrate and distilled water should only be used??
chipmunck
5.0L Coyote
Oct 10, 2016 04:35 PM
smithm31
20
May 3, 2016 11:06 PM
Whitey Ford
Oct 10, 2015 12:33 PM
mongo12
38
Dec 6, 2010 11:58 AM
itsalunker
Oct 31, 2010 09:34 AM
