Leveling kit or Bilstein 5100's
Old Dec 20, 2010 | 04:13 PM
Brack1's Avatar
Brack1
So what's the difference between using the Bilsteins and putting a spacer on the current struts? Obviously the new struts will cost more, but is it a better solution? I desperately want to level my truck and the local Les Schwab quoted me $230ish to put in spacers and align it. Which sounds good, but will doing that introduce problems later? The truck has a hair under 130k on it and I have no idea if the struts have been replaced yet. But here is my biggest worry, will leveling the truck cause other issues? Stuff like wearing out the ball joints faster, putting more pressure on the suspension and blowing other stuff out, or causing klunk and clank noises when turning or going over bumps. I really know very little and want to make an educated decision because I don't have the funds to fix stuff constantly.
Old Dec 20, 2010 | 04:27 PM
The Oldtimer's Avatar
The Oldtimer
I had a Daystar leveling kit installed when my 04 FX4 Scab was new...I only have a little over 40,000 miles on it, but I haven't had a single issue with it. The original tires are still on the truck, so alignment is not an issue.
Old Dec 20, 2010 | 04:56 PM
Joe04F150's Avatar
Joe04F150
I know I'm in need of new shocks so that's why I'm considering the bilsteins and leveling it all in one.
Old Feb 7, 2011 | 08:43 AM
Joe04F150's Avatar
Joe04F150
Finally got my Bilstein 5100's on, they're set at the highest setting, the front is a half inch lower than rear. Love them!
Old Feb 7, 2011 | 09:00 AM
1bad67sbf's Avatar
1bad67sbf
looks good!!!
Old Feb 7, 2011 | 09:23 AM
Joe04F150's Avatar
Joe04F150
Thank you! Only thing I was a little worried about was the 4wd vac lines going to the hub, not allot of slack now. I ended up putting a tie wrap on the end to help them stay on there.
Old Feb 7, 2011 | 09:34 AM
1bad67sbf's Avatar
1bad67sbf
how much true lift over stock do you have at the highest setting? i did not pay much attn to my iwe lines but i have had no issues at 2.5in on mine
Old Feb 7, 2011 | 10:52 AM
powerz69's Avatar
powerz69
Nice! did you install them yourself?
Old Feb 7, 2011 | 11:45 AM
Joe04F150's Avatar
Joe04F150
I measured in the garage prior to the install and had just under 6" tire to fender clearance, after I installed them I drove it around for a few minutes and pulled it back in the garage and measured exactly 8" ...so I'm guessing I got 2"- 2.25 +/-. The back has 8.5 from tire to bed, I like the way it sits now.
Took about 1 1/2 hrs to install ....taking my time, pretty easy.
Old Feb 7, 2011 | 12:14 PM
tooldad's Avatar
tooldad
No problems on mine except for alignment, which has been fixed now I think. Apprently there is little camber adjustment from the factory. Had it aligned immediately after 2" AS install and again about one year later, but had premature outer edge tire wear. as I understand it, some F150's require the addition of a camber kit with alignment in order to have even tire wear. I just had that done Christmas Eve, so the verdict is still out. Cost for that totalled about $330 at 4WheelParts using a more expensize NAPA camber kit ($120). The truck had about 42k at install and now sits at 98k.
Dr.Huxtable
Jul 11, 2018 08:49 PM
fordman19762003
2009 - 2014 F150
Jun 26, 2016 07:43 AM
PokerMunkee
Mar 21, 2016 12:30 AM
AtlantisBuilt1
Ford Truck Parts for Sale
Feb 9, 2016 08:20 PM
rcklnhunter
6.7L Power Stroke Diesel
35
May 20, 2011 04:53 PM
