Tranny Question
Old Dec 14, 2010 | 08:05 PM
Brian's 48's Avatar
Brian's 48
Tranny Question
I'm building a 48 F1 with a 300/6. The rear has 3.73 gears and the tires are 29" tall. With the C6 I have now I'll be running about 2600 rpm @ 60 mph. I'm wondering if anyone can give me info on how the 6 handles the AOD. I've read where the C6 draws alot of power, is the AOD any better?
Thanks,
Brian
Old Dec 15, 2010 | 11:41 AM
Rogue_Wulff's Avatar
Rogue_Wulff
AOD takes less power/torque to operate, and will usually hold up pretty decent behind a 300, if it has been properly adjusted when 1st installed.
The C6 consumes the most power when 1st starting to move. Once you're moving, the power consumption drops rather quickly.
Really, the biggest advantages of the AOD are taller gearing + locking convertor = better MPG. This is even more true with 3.73 rear gears.
Old Dec 15, 2010 | 04:47 PM
Brian's 48's Avatar
Brian's 48
Thanks for the reply, thats the info I was hoping for. The OD would make the highway cruise much better.
Brian
Old Dec 15, 2010 | 11:11 PM
85e150's Avatar
85e150
Look for an '88-'93 AOD, and consider some beef up work. Most of the issues were ironed out in those models.
In the propaganda at these sites, you can see what they offer in their transmissions, and what parts they sell to compensate for AOD issues:
AOD Transmission from PATC, AOD Transmissions
TCI - Ford AOD, AODE and 4R70W
AOD Performance Products - Baumann Electronic Controls
www.CKPerformance.com
Old Dec 16, 2010 | 09:31 PM
nevrenufhp's Avatar
nevrenufhp
My nephew did just that swap. A C6 to an AOD and loves it. Cruises down the highway ever so easily. The AOD also has a little lower 1st gear, so it helps when taking off. All he did differently to the engine was put in lighter step up springs in the carb(Edelbrock). No word on the new mpg's yet.
Old Dec 16, 2010 | 09:55 PM
furius's Avatar
furius
i just got a little bit of an education on this myself i would personally suggest E40D it is a little stronger and you would still have your 3speed auto with overdrive
Old Dec 17, 2010 | 12:33 AM
85e150's Avatar
85e150
E4OD is a lot stronger, BUT it's as big as a house, and requires a $500 controller for the OP's application. Other than that.....
Old Dec 17, 2010 | 04:22 PM
Brian's 48's Avatar
Brian's 48
Thanks Guys, I think I'll go the AOD route, no electronics to mess with. I don't think strenght will be an issue since I'm building a cruiser not a racer.
Brian
wa-sleeper
Oct 22, 2016 03:04 PM
bankog1
Oct 23, 2015 11:50 AM
bankog1
Oct 14, 2015 02:07 PM
RyanSbigblue
21
Apr 25, 2013 02:03 PM
RP27G8G
Oct 23, 2006 09:43 AM
