Tool guide at Xmas
Old Dec 12, 2010 | 05:37 PM
tip49's Avatar
tip49
Tool guide at Xmas
Thought this may be usefull when requesting tools this Christmas:
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh--!'
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT (COMMON) SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
SON-OF-A-B*TCH TOOL: (A personal favorite!!) Any handy tool that you grab and throw across the garage while yelling 'Son of a B*TCH!' at the top of your lungs. It is also, most often, the next tool that you will need.
Merry Christmas !
Old Dec 12, 2010 | 05:56 PM
HILLBILLY BOB's Avatar
HILLBILLY BOB
I really like that,do you have any more? I am sure that the guys & julie will
come in with a few others too
Old Dec 12, 2010 | 07:18 PM
Wayne S's Avatar
Wayne S
Pretty funny.Most all of my tools are the SOB variety.
Old Dec 12, 2010 | 07:27 PM
Mervy49's Avatar
Mervy49
Bin there done that.....ya, too funny!
Old Dec 12, 2010 | 09:10 PM
Julies Cool F1's Avatar
Julies Cool F1
SUPER GLUE: For mending broken fingernails!
DUCT TAPE: For anything but ducts!
LOL, (ok I'll just shut up now)
Old Dec 12, 2010 | 09:13 PM
52 Merc's Avatar
52 Merc
I'm happy to say I have one of each, except for the drill press and table saw. Now I know what to ask Santa for Christmas. ;-)
The one thing that got left off the list above was polisher wheel. Similar to wire wheel, but designed to turn your rare and expensive stainless trim into pretzels and throw them into your chest at light speed. Don't ask me how I know. ;-)
Old Dec 12, 2010 | 09:27 PM
coopdagook's Avatar
coopdagook
Don't forget the drill, used to find wires or hoses behind firewalls. Used it to find a brake booster once .
Old Dec 12, 2010 | 10:14 PM
fifty-two_f1's Avatar
fifty-two_f1
EASY-OUTS: used to break off in bolt you were trying to remove so that it becomes absolutely impossible to re-drill it.
PUNCH: most commonly used to swell out the end of door hinge pins
Old Dec 13, 2010 | 11:22 AM
WALFORD'S 56's Avatar
WALFORD'S 56
After being in machine shop business , have seen the best and worst use of tools...LOL
Old Dec 13, 2010 | 02:28 PM
Mervy49's Avatar
Mervy49
I have a collection of crescent wrenches, (inherited). I swear that they make a better hammer than a wrench
Old Dec 13, 2010 | 03:09 PM
edzakory's Avatar
edzakory
Stud Finder: Wife's personal favorite. Points in opposite direction of me.
Variable Speed Oscillating Multi-function Power Tool: Wife's backup for Stud finder.
Old Dec 13, 2010 | 03:36 PM
cobraguy's Avatar
cobraguy
Chop Saw: Used to make any long piece of metal too short
Carb Spray Cleaner: Used to blast tiny objects directly into users eyes regardless of where its aimed
Wire Welder: used for sculpting bird poop on metal panels
Old Dec 13, 2010 | 09:24 PM
havi's Avatar
havi
I'll have the Roast Duck
I do all my shopping here: KaleCoAuto, Hard to find automotive items!
