215ci not starting
Old Aug 5, 2011 | 06:30 PM
  #91
badger_hound's Avatar
badger_hound
Here's one on ebay for $60:
52 53 FORD 215 CRANKSHAFT | eBay
Should fit a 51? $90 to ship though... yikes!
Old Aug 8, 2011 | 12:03 AM
  #92
51PanelMan's Avatar
51PanelMan
Originally Posted by ALBUQ F-1
Is a 223 crank interchangeable?
Why not bore the snot out of it, and if the 223 had a bigger stroke, throw that in too. Make it into a 250 c.i. torque monster!
I believe that the 54-60 223 is different because of the bigger stroke, so is the crank from a 262.
I'd like to keep the engine stock and not a hybrid monstrosity. However, if I can't find a good 215 crank, I may have to go with a good 223 crank.
Thanks Mike. I saw it on Friday when I was searching Google for a 215 crank. I pulled another crank out of a parts motor on Saturday and dropped it off at the machine shop. I'll know on Wednesday if that crank is any good. I'm hoping that it is. If not, then I may have to drop the $150 on the one on Ebay if it's still available. Still no gaurantees on that one either.
Old Aug 10, 2011 | 04:10 PM
  #93
51PanelMan's Avatar
51PanelMan
Another update.
2nd crank was found to be cracked as well. The search has begun for a good crank.
Found a vendor online that has two cranks from a 215 (one from a 52 and another from a 53). The vendor will have them magnufluxed to see if either one (or both) are any good. If he can get at least one good crank, it'll cost me close to $200 with shipping. Ouch!
Old Aug 10, 2011 | 04:33 PM
  #94
old_dan's Avatar
old_dan
If you want....I'll give you a complete 215...the crank is probably good. The engine "ran when parked"...
Dan
Old Aug 10, 2011 | 04:47 PM
  #95
51PanelMan's Avatar
51PanelMan
Dan
I appreciate your offer. However, at this point, I'm done with taking engines apart and dealing with the mess. I have another complete 215 at home that also came out of a running car, but I'm not in the mood to take apart another engine, especially one that's complete and together.
I should have never thrown away the other 215 block that I had, which still had all of its internals. That block probably had a good crank.
I already put down a $100 deposit with the vendor. I'll get a refund if both cranks are bad. If they are, then I'll let you know and will gladly take you up on the offer.
Old Aug 10, 2011 | 06:02 PM
  #96
ALBUQ F-1's Avatar
ALBUQ F-1
Are those cranks cracked on the front nose? Did the 215's use a harmonic balancer or a plain front pulley (cast iron)?
Old Aug 10, 2011 | 06:13 PM
  #97
38 coupe's Avatar
38 coupe
The 215 and 223 have the same stroke. The difference between them is the bore. It is common to bore 215s to 223 standard when rebuilding as the pistons are easier to get (or at least used to be...).
Old Aug 10, 2011 | 07:21 PM
  #98
badger_hound
Originally Posted by 51PanelMan
Another update.
Definitely ouch. But at least you'll know you have a good part to work with.
Old Aug 24, 2011 | 02:18 AM
  #99
51PanelMan's Avatar
51PanelMan
The good news is that the crank turned out to be good after magnafluxing and I received it last Friday.
The bad news is that when I opened the package today at the machine shop, we found this...
Thanks to UPS, the it's now a custom two-piece crank. The box was marked FRAGILE in several areas and also had a UPS sticker stating that the box was very heavy. The box didn't have any obvious damage on the outside, but one drop on an end would cause the crank to break. I called the seller immediately and advised him of what happened. He's supposed to call me back tomorrow to let me know how he'll rectify the situation. He has another crank and I'll ask him to send it to me as a replacement at no cost if it's good after being magnafluxed. If not, then I'll request a refund and will try to find another crank somewhere else.
What a bummer!!!
Old Aug 24, 2011 | 08:35 AM
  #100
ALBUQ F-1's Avatar
ALBUQ F-1
It should be shipped in a wood-reinforced box, obviously.
I think a flat V8 is in your future!
Old Aug 24, 2011 | 09:45 AM
  #101
51PanelMan's Avatar
51PanelMan
I pulled the flat V8 a few years ago to put in the 215. That'll be like dejavu.
Old Aug 24, 2011 | 11:13 AM
  #102
badger_hound
What crappy luck. As long as the seller insured the shipment, I would think he'd be pretty prompt about a replacement or a refund.
Old Aug 24, 2011 | 12:14 PM
  #103
old_dan's Avatar
old_dan
Ilya,
I still have the 215 and the complete powertrain from my F2....wrapped up and waiting for you to take the crankshaft (and the rest of the engine).
I'm pretty sure that since this was a good running truck when it was parked there is no reason to think that it'd have a cracked crankshaft.
Dan
Old Aug 24, 2011 | 12:31 PM
  #104
ALBUQ F-1's Avatar
ALBUQ F-1
I'd be real interested to see a super-close-up of the break. Maybe it's a shadow, but it looks to me like it was cracked already along the line in red. I think it would take more than a casual bump to crack a crank in half.
Old Aug 24, 2011 | 12:38 PM
  #105
51PanelMan's Avatar
51PanelMan
Ilya,
Dan
Thanks, Dan. It may have to go that way if the vendor can't replace the broken crank. I'll let you know.
