question about changing rearend gears
Old Dec 11, 2010 | 04:17 PM
TAT2DUP81's Avatar
TAT2DUP81
06 f350 dually 4x4 wit 410 gears...wanting to change to 373. Is the any issue with doin this on a 1 ton truck?? Also 2nd question..does anyone wit similiar truck have a rattle under dash at idle when coming to a stop??
Old Dec 11, 2010 | 04:42 PM
smokersteve's Avatar
smokersteve
You will have to change your spedo, and get 2 sets of gears. Other than that I see no issue.
Old Dec 11, 2010 | 05:12 PM
TAT2DUP81's Avatar
TAT2DUP81
Sorry to sound retarded but what u mean by new speedo and 2 sets of gears? So is front 410 also what u mean by that?
Old Dec 11, 2010 | 07:21 PM
adambomb's Avatar
adambomb
yes Steve is right. because of the 4x4 you need to do both the front and rear diffs.
Old Dec 11, 2010 | 07:23 PM
adambomb's Avatar
adambomb
rattle from dash
could be from the down pipe touching the firewall. this can happen if you have recently removed the exhaust from the turbo or the down pipe is loose.
Old Dec 11, 2010 | 07:26 PM
Jigger2020's Avatar
Jigger2020
Tat I hope you don't plan on doing this yourself
Old Dec 11, 2010 | 07:36 PM
TAT2DUP81's Avatar
TAT2DUP81
Lol no. But my transmission was rebuilt and the down pipe coming loose does make sense.
TAT2DUP81's Avatar
TAT2DUP81
But wouldn't I get a check engine light for exhaust leak??
Old Dec 11, 2010 | 07:37 PM
smokersteve
If you have the tools to do this, you can do it over a weekend easy. if you don't......... It may not be done right and it will take for ever.
Yea, you got to get 2 sets of gears and shims, I think that's it. And re-set your speedo because you are changing the rotating speed of the diff and that is where the truck gets the MPH from.
I wold normally do it my self if I had the tools, but I do not have the knowledge to do it and the risk of screwing it up is big with that. So I suggest getting a shop to do it if you are not familiar with the job.
I also suggest putting amsoil in the diffs. I did and I am glad I did
Old Dec 11, 2010 | 07:48 PM
TAT2DUP81's Avatar
TAT2DUP81
Smokersteve...I truely appreciate yours and everyone else input. Thanks
Old Dec 11, 2010 | 07:56 PM
npccpartsman's Avatar
npccpartsman
I think you're making a mistake going to 373's on a dually. You're not going to gain any fuel mileage if that's your goal. you might actually lose mileage and make your EGT's higher. 6.0's LIKE a little higher RPM's
Old Dec 11, 2010 | 08:16 PM
Jigger2020's Avatar
Jigger2020
listen to the Partsman he know's what he's talking about
Old Dec 11, 2010 | 08:18 PM
sammy77's Avatar
sammy77
There is little to no difference from a 4.10 vs 3.73
Old Dec 12, 2010 | 03:45 AM
npccpartsman
Didn't the dually's actually come from the factory with 4.30's anyway?
TAT2DUP81
Jan 21, 2011 11:27 AM
beeturbo
Dec 18, 2008 07:14 AM
SilverFish
Tennessee Chapter
15
Mar 3, 2007 04:08 AM
gramses
Sep 7, 2006 09:45 AM
epicxtreme
Exhaust Systems
Aug 28, 2003 05:24 PM
