Lifting D-60 (front)
Old Jan 14, 2003 | 06:34 PM
jaybird2003's Avatar
jaybird2003
Post Lifting D-60 (front)
I have a 1987 F-350 crew cab 4x4. I just put some ground hawg 40's on but need more than the 3inch body lift that is already on the truck. I have the back blocked and was thinking of blocking the front. Is that safe? Will that effect my steering? Will I need a drop steering arm? Jason in TN.
Old Jan 14, 2003 | 06:36 PM
mooktank's Avatar
mooktank
to lift the front youre supposed to get new springs. I think you can do up to 4 inches of lift without correcting steering stuff. You could use a block if you welded it in but that creates axle wrap which nooone really likes.
Old Jan 14, 2003 | 07:24 PM
jaybird2003
What is axle wrap?
Old Jan 14, 2003 | 07:54 PM
AggiePSD's Avatar
AggiePSD
When you apply torque to the axle it will tend to wrap or twist forward or backward because there is friction between the wheels and the ground. Adding blocks will make wrap more noticeable and easier to happen because the distance from the axle to the spring is increased.
Old Jan 16, 2003 | 06:40 AM
dvldog458's Avatar
dvldog458
You might be able to get away with an add-a-leaf in the front.I think they make them with a 2 1/2" rating.Just unbolt the U-bolts and slip that bad boy underneath and your good to go.
I'm pretty sure Skyjacker and Superlift make them.
Good luck.
Jerry
Old Jan 16, 2003 | 08:05 AM
honney's Avatar
honney
You'll get a better ride and about 2" lift if you do something like this:
http://www.offroadunlimited.com/oru_rshacklekit.htm
But I wouldn't pay ORU's prices - you can make something yourself and you don't have to have the crossmember bar between the two front hangers.
Otherwise an add-a-leaf or new spring packs....
Old Jan 16, 2003 | 01:24 PM
dvldog458's Avatar
dvldog458
I'm with Honney.
I have that setup,and it's one of the best things i've done to my suspension.
But gets alittle pricey!
Old Jan 16, 2003 | 01:53 PM
jakegypsum's Avatar
jakegypsum
jbravata2
Mar 2, 2014 07:04 PM
carcus
May 11, 2013 08:49 AM
93f250tn
Dec 3, 2010 03:31 AM
r0n1n
Sep 26, 2004 11:46 PM
fishmanndotcom
Aug 14, 2002 05:55 PM
