defrost default
Old Dec 10, 2010 | 04:43 PM
mrp1340's Avatar
mrp1340
defrost default
2004 6.0, I replaced the vaccum pump based on info. I found within these posts & it worked for about a week but now I'm having the same problems; air selector doesn't work, only defrost and no 4X4 unless I get out & manually lock the hubs. What gives? I would appreciate any tech. help. Thanks
Old Dec 10, 2010 | 04:53 PM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE mrp1340, make sure you read through the Tech Folder at the top of this forum.
I would plug off the vacuum line going to your front hubs and see if that solves your in cab control problems. If it does your front hub seals are shot which holds the vacuum to engage the front hubs. Is the pump constantly running? Do you have manual or auto climate controls for the heat/AC?
Old Dec 10, 2010 | 07:30 PM
clane's Avatar
clane
try the 4x4 valve by the pump on the fender white top too bolts part#7c3z-9h465-a
this was my fix on a 05
Old Dec 11, 2010 | 10:05 AM
mrp1340's Avatar
mrp1340
thanks for the info. but how do know which line is going to the hubs? Going to check tech folder. New to this site still learning my way around.
jcfcoyle
Jan 12, 2015 04:52 PM
thejean
6.7L Power Stroke Diesel
19
Nov 6, 2014 06:15 PM
sagicorn62
2004 - 2008 F150
Nov 9, 2007 05:22 PM
Scurv
1997 - 2003 F150
Jul 18, 2003 09:51 AM
Scurv
Jul 18, 2003 07:37 AM
