Crazy Question
Old Dec 10, 2010 | 12:25 PM
bchez's Avatar
bchez
Post Crazy Question
I have an 07 F-150 and heard that they have a multi-piece spark plug in them. Any truth to this and when should I change them? I have 61,000 on it now.
Old Dec 10, 2010 | 05:41 PM
pete497's Avatar
pete497
It's not multi piece until you try to remove it.
Old Dec 10, 2010 | 08:16 PM
bigunit54's Avatar
bigunit54
hahahahahaha
Old Dec 11, 2010 | 12:49 AM
ChrisCarter's Avatar
ChrisCarter
This is very true... They fixed it on 07, BUT I heard some of the earlier 07 models were still effected. Even with 61 thousand miles on it, if you are one of the unlucky 07 owners that were made before they swapped over to the new heads, then you will still end up breaking them off. They make a tool to get them out, 60 bucks on Amazon.
It is time consuming.
Go here,this guy gives a pretty good detailed description on getting those plugs out.
Old Dec 13, 2010 | 10:51 PM
pelphrey's Avatar
pelphrey
I have a 04 5.4 with right around 103,000. Just had all plugs replaced and 2 broke. I'd say I got lucky!!! haha
Old Dec 14, 2010 | 07:34 AM
Techfree's Avatar
Techfree
They aren't really that bad to deal with if you have the proper tool. Sometimes you can find them on e-bay for around 35 bucks. The issue is that the bottom extension of the plug is a separate sleeve that is pressed onto the main plug and they will seize the walls of the cylinder head, then when trying to remove them they will actually separate from the main plug and sometimes ( most times ) will break off the porcelain with them, a very nasty mess to deal with without the appropriate tool. Champion makes a replacement plug that is an all steel one piece plug that will alleviate this problem in the future, don't know why motorcraft can't.
Old Dec 14, 2010 | 09:25 PM
AspenGreenMetallic's Avatar
AspenGreenMetallic
I would highly recommend the Champion plug when you do undertake this "routine maintenance."
I shopped around and found the best price at the time from Summit Racing, part number CPN-7989
They are a little more pricey, but as far as I know are the only 1-piece replacement as of yet.
Old Dec 14, 2010 | 09:57 PM
Oldguy4's Avatar
Oldguy4
What I understand is that the fix came in late 2007 so that would make those 2008 models.
Old Dec 17, 2010 | 01:37 AM
PintoGuy's Avatar
PintoGuy
I've stuck with Fords my whole life but everything I own is many years old. Stories like this make it hard to maintain brand loyalty. I am not looking forward to the day when I will need to purchase a 'modern' vehicle...
Old Dec 20, 2010 | 08:13 PM
glincecum's Avatar
glincecum
There is a class action that I've seen on the web.
Deerhunter76
Jun 12, 2015 11:20 PM
glovemeister
Feb 4, 2015 04:23 PM
Aero750
Mar 25, 2014 03:25 PM
77f100guy
17
Jan 19, 2010 10:47 PM
