Footwell Lights
Old Feb 2, 2015 | 08:15 PM
glovemeister's Avatar
glovemeister
Footwell Lights
Anyone have them in their truck? I know that mine doesn't have them, but was hoping it was a factory option or something. Looking to install some.
Old Feb 2, 2015 | 08:21 PM
DougJ_1997PSD's Avatar
DougJ_1997PSD
not stock, but you can wire some up with lights from autozone or something. it wouldnt take too long
Old Feb 2, 2015 | 09:04 PM
fordman67's Avatar
fordman67
dent side fords had some under dash lights. I think they reproduce them. eaisly mounted also.
Old Feb 3, 2015 | 05:51 PM
Diesel_Brad's Avatar
Diesel_Brad
Very easy to wire in some pop in lights. if you want to get all ricey, they come in different colors too
Old Feb 4, 2015 | 11:27 AM
granny_rocket's Avatar
granny_rocket
you can buy a roll of "bare" LED lights (they're not weather sealed is all that "bare" means) - 16.6' long for around $16. They have an adhesive on the back, are about 3/8" wide and have 3 leds about every inch. You can cut them every inch and they have solder points. This is of course if you don't mind doing a little soldering. BUT I used these inside the cap on my other truck and WOW they're awesome. I saved a few feet and plan to run a few under the dash somewhere. I actually made my own lighted rearview mirror in my '84 as well using a 1" piece on either side of the mirror flip thingy (yes it's a technical term).
Just my 0.02.
I'm sure also if you were in the junkyard you could find a factor courtesy fixture from an old Crown Vic, Mercury Marquis or something of that sorts. Even GM used them in the Cutlass's (at least mine had them).
Hope this helps,
Old Feb 4, 2015 | 04:23 PM
tractoman's Avatar
tractoman
I put some in my truck that I got on ebay. They were out of some mid 70's Ford of some sort. Pretty straight forward and a huge improvement in lighting.
George D.
General Diesel Discussion
16
Mar 23, 2008 08:54 PM
79driver
Aug 24, 2006 10:21 PM
wrm
Sep 27, 2005 07:48 PM
