portable heater help
Old Dec 9, 2010 | 02:24 PM
jaye's Avatar
jaye
Do anyone know of a good portable heater that will plug into a lighter; it's unseasonably cold here (16-28 degrees), by the time I get to work the truck is just getting warn.
Old Dec 9, 2010 | 02:41 PM
3414's Avatar
3414
You will not find a 12 volt heater that does much more than warm the hand you hold it in. Most are 300 watt at the most with very low flow fans. Here is a trick I have used in really cold weather - just take a cheap 120 volt ceramic heater and a 12 ga extension cord. Put the heater in the truck and turn it on high about 45 minutes before you go. When you go, turn heater off, unplug from extension cord, and you have a nice warm cab for a while.
Old Dec 9, 2010 | 03:02 PM
52 Merc's Avatar
52 Merc
Something else to consider might be a block heater for your engine. You leave it plugged into your household current overnight and it'll have the water in the engine up to about 100F when you start the truck in the morning. It'll start easier and get warm faster so your drive is a lot more comfortable.
Old Dec 9, 2010 | 05:44 PM
HILLBILLY BOB's Avatar
HILLBILLY BOB
Jaye, something else to consider is a remote start,i had that in my truck
when i lived in nj turn your defroster on at night & in the morning you hit
the remote start,the truck starts-the defroster comes on & when you
get into the truck the windshield is clear & the truck is nice & warm-it
was good in the summer too with the ac
Old Dec 9, 2010 | 06:05 PM
r_reed's Avatar
r_reed
the old school remedy was to put a piece of cardboard over part of your radiator. of course, you have to monitor your temp gauge to make sure you don't overheat it. mine seems to warm up quicker with about half the radiator covered. dick r.
Old Dec 9, 2010 | 06:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I used a tank-type block heater for years and loved it! In 1/2 hour the engine was about 140 - 160 deg, started like a dream, and the defrosters worked almost immediately. The only thing it to make SURE you unplug it before you pull away!!
What thermostat you running?
Old Dec 9, 2010 | 07:39 PM
Julies Cool F1's Avatar
Julies Cool F1
Oh just put on a jacket ya big woos! LOL!
I'm just kidding.
It sounds like Ross is onto something. Your heater takes raw heated coolant from the engine. If you have a 140 degree thermostat, that water going into you heater is going to be 140 degrees before the thremostat even opens. That should be more than enough.
Are you sure your heater lines are un obstructed - heater temp valve (if installed) is working right - blower is blowing enough?
Old Dec 9, 2010 | 08:44 PM
38Chevy454's Avatar
38Chevy454
An in-line lower radiator hose block heater is an easy and effective solution for quicker warm-up. Itjust splices in line, typical is 600 watts, 120 v.
Old Dec 9, 2010 | 09:16 PM
havi's Avatar
havi
I'll have the Roast Duck
Originally Posted by 38Chevy454
An in-line lower radiator hose block heater is an easy and effective solution for quicker warm-up. It just splices in line, typical is 600 watts, 120 v.
This is what I used when I did the engine swap in my Bronco (so I could keep the stock radiator) to join the two hoses. Works great, but don't leave it plugged in for three days straight, you might get a shock when you see the utility bill.
Up here in the tundra, we just deal with it. Get up earlier, start the truck earlier, leave earlier, get to work late.
Old Dec 9, 2010 | 10:52 PM
Lakotas53's Avatar
Lakotas53
As stated above DO NOT buy the small portable heaters that plug into a cigarette lighter. Useless, just go to Harbor Freights website and read the reviews on the one they sell. Most customers gave it a 1 star rating.
Old Jan 3, 2011 | 06:30 AM
Sgt Wonderful's Avatar
Sgt Wonderful
Tank heater is the way to go. Plugs into your water/cooling system and keeps it warm all the time. (works like a electric coffee pot) Used it in Northern Minnesota. Let truck set for weeks on end - outside 30 below - raw temp not wind chill - had warm heat on startup.
Old Jan 3, 2011 | 07:13 AM
iwanaflattie's Avatar
iwanaflattie
why not get a 12v converter to 110,the one that plugs on the cig lighter and run a bigger heater...you can use the converter for alot of things
Old Jan 3, 2011 | 07:30 AM
Sgt Wonderful
drains the battery
Old Jan 3, 2011 | 09:47 AM
jaye's Avatar
jaye
Thanks for the replies Guys I was looking at the ones from HF; I guess I'll just suck up and put on a coat.
Happy New Year!
swaybar
16
Jan 21, 2025 02:12 PM
tazo
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Dec 11, 2009 07:57 AM
magneto259
Nov 22, 2008 09:04 AM
PigFarmer
Garage & Workshop
Jan 31, 2003 12:32 PM
vinny8
Dec 5, 2002 12:53 AM
