Was 9 degrees this morning.........Iw as lazy and plugged it in last night before bed.......mostly because I was planning on just starting her in the monring and then taking my other truck to work as I still have one questionable battery, which I'm buying two new ones next week (get paid today).......started right up and I decided to take her to work.
Threw a few gallons of fuel in this morning......friggin' $3.399/gal.......awesome......gotta love heating season and a ******* gas station owner. He's the only diesel on this strip now after a guy went under and he is right off the highway so on Friday's he raises the prices $.05 on everything......**** By some miracle the price always goes down about noon Mondays.....
Reason: Remove comments that were not forum material
Yikes. I'll probably stick with the gasser during the winter for the most part, give the 7.3 a couple runs per week when I get sick of the other truck.......of course I need tires for the other truck as I've been lucky with snow.
i have block heater and a external oil heater, with 2 battery blankets that are all pluged in to a timer and it works good. some people say i went a little over board on the heating stuff but it below zero here a lot.
I've been using the three hrs before leaving timer, and I can't see much difference in the starting engine/water temp. What kind of results are you all seeing? I know ambient temp will factor it, but say if it is 10-20 deg out and the heater is on for three hours, what temp might the engine be at on initial start? I know it is a dumb gauge, so are we talking at the C, in op range? I get below the C and the EBPV valve kicks the idle up so I know the engine isn't seeing much...thanks
All I really have noticed is quicker/easier cranking & warm up - never really paid attention to whether there was any diff in the gauges plugged in vs not.
The deal closer for me on using the block heater is: I get heat in the cab just a few miles down the rd vs 12-15 miles w/o the heater plugged in
My wife works the normal bankers hours. i work an odd shift so a lot of times she leaves 4-5 hours before I do. When it gets down into the teens, she will plug the truck into the wall on her way by it. She usually does not know what time I will leave or when I will get back. If it is one of the days where I do not leave until 2 pm, the water gauge is usually right at the bottom of the normal range when I crank the truck. Last night when we got in, I plugged it in when it started to snow. We only got about 3 inches, but both trucks were parked next to each other. The SD had no snow on windows while hemi powered dodge had snow all over windows and hood. we had driven the dodge so it was the warm one when we got home.
I have a timer on mine as well. It's rated for 15amps and the Extension cord is heavy duty. Seems to work great, no problems at all. I usually let mine warm up about 3 hours before going out to start it and since I haven't as of yet fixed my GP issues it makes starting much smoother. Without plugging it in I can bellow some serious smoke and she rocks like crazy for a minute or so.
If it's plugged in then it starts nice and smooth.
