351M
Old Dec 8, 2010 | 10:57 PM
C-700's Avatar
C-700
Question 351M
Have a 351M I rebuilt. Just barely runs, can not get much vacuum. Indication is the valve timing. Can I put a wrong timing chain and gear set on or maybe a wrong cam. Any ideas. Have good cranking compression and Ignition. Timing is set correctly.
Old Dec 9, 2010 | 08:37 AM
80broncoman's Avatar
80broncoman
Yes to all your questions. What do you mean timing is correct? To factory specs?
Is this a stock rebuild?
Old Dec 9, 2010 | 09:06 AM
C-700's Avatar
C-700
Stock rebuild, both ignition timing and alignment of marks on the timing gear set are correct. I know that other cams for that engine will interchange but could I have a cam for a different engine series in this?
Old Dec 9, 2010 | 09:12 AM
6fifty_f1fifty's Avatar
6fifty_f1fifty
If you got an excessively agressive cam for the components that you have, that could be what is causing your low vacuum. The vacuum is created by the cylinders drawing in air for combustion and you have to have the right combination of lift/duration/overlap combined with flow characteristics of your intake and heads.
That very reason is why some racers and performance monsters switch to a hydroboost assisted brake system, to conserve vacuum (or because they don't have enough vac).
Old Dec 9, 2010 | 03:55 PM
BrutalBronco's Avatar
BrutalBronco
351m
how much cranking compression do you have? I had a 400 with 7/8 top rings cracked that always gave fits to start, but when it would, ran just fine. Had I known that damage was there, I would have overhauled it 2 years earlier. With low vacuum, your carb won't have enough signal to function much past the idle and transfer circuits. I would check out the intake/carb for leaks, and all vacuum ports are functioning/capped and accounted for. additionally, like 6fifty pointed out too, that too large of a cam will cause lower than stock vacuum. could u share any specifics?
Old Dec 10, 2010 | 08:11 AM
6fifty_f1fifty
Thanks for adding to that Brutal, I was thinking of mentioning vac leaks to as they are probably the biggest cause for poor running engines (besides Arco gas )
Old Dec 11, 2010 | 08:44 PM
C-700's Avatar
C-700
The vacuum leak is a possible. Have not removed the intake yet. My first thought was the timing gear alignment. I have never goofed on that in hundreds of rebuilds but there is always that first time. It check out OK. I had the machine work done at a machine shop/parts house so I got everything as a kit. I thought maybe it was possible the cam and or the timing gear set was for a different engine and causing my problem. I have not put a degree wheel on it yet to check valve timing. Kids have lost the wheel and I have to buy another. All of the parts are stock replacement. The engine would idle if I advanced the ignition timing and all cylinders check out pretty even, RPM drop test. Have opened up the exaust by removing the exaust back to the headers. I got pis'd at this and have not touched it in a year. During the year the shop I bought the parts from went out of business and I can't find the receipt. I am just having to much fun. Thanks for responding
tustuck
Mar 29, 2009 03:34 PM
Awsum77
Nov 12, 2004 09:17 AM
fordguy351w
Oct 5, 2003 04:19 PM
bruce351
Aug 28, 2003 10:09 AM
timberbuck
Jul 24, 2002 07:47 AM
